Project DTZr.....a DT125R love story
@Calum said in Project DTZr.....a DT125R love story:
@Hark_Ptooie If the spark plug gap isn't set correctly than the spark can just break down at too high a load. The spark plug annodes are saturated with voltage from the HT coil, if the gap is incorrect then this will cause issues.
Ah - makes sense.
@Hark_Ptooie I'll refresh the soldering as soon as possible because this problem drives me crazy.Everything is almost ready except this and cannot go for technical inspection.
@Calum I'll order a new spark plug cap from Yamaha dealer,although the current is within specs and the original one.I prefer to have a backup if not used
@SpookDog no such box on this model,It matches the cable harness of 3RN1 to 3RN9 of Haynes manual or the 3NC that @HOTSHOT-III posted to another thread if memory serves correctly.Side stand switch connects with negative and then to CDI blue/yellow.
@HOTSHOT-III said in Project DTZr.....a DT125R love story:
The actual coil on DTRs is very good quality so it's well worth fitting a new lead even to an older one; you can cut off the very top of the coil's outer case where the lead pushes in with a junior hacksaw, pull out the old lead and solder the new one to the coil output for a really good connection. Then re-waterproof using Shoe Goo and electrical tape. Looks messy but no-one can see it under the tank.
Do you have any photo to see what you did,it's interesting to know,I have an old one with short cable.
Sorry to keep on asking about the side stand switch stuff. Your CDI must have an embedded controller…
If I was you I’d try: running a new wire from the magnetic pickup to the CDI, also the wire from the CDI to the coil. You’ve swapped out everything else electrical that I can think of for the time being…
The ‘resolution’ of the ignitions ‘pulse’ is loosing ‘fidelity’ somewhere. There can’t be that many places left to look… -
I didn’t realise you were still having this problem!
I need to go back over and read it again…Is your bike one of the ones deristricted with the read switch?…
Edit: Just read back some and I’m interested in the ‘sparks from side to centre’ bit.
Did you ever swap out the CDI?… -
My memory doesn’t serve me very well bud! 😜
If it’s still doing the weird spark I’d try replacing the orange wire that runs to the coil, as far back as possible. It sounds like you may have a break inside the insulation, that is causing a weak or intermittent spark…
No plug should spark like you stated when it’s dry and clean…
Pin the valve then if it still does it you know its not the servo
The black an white wire ( kill switch to cdi ignition ) can cause it to.spark every other kick.but yours is getting to 5000 rpm so I doubt it's that
One thing to remember half the wires in these looms the copper has turned black even though they look OK on the outside
