  3. Derestricting
  4. Ideas on tunning
Ideas on tunning
24 Posts 5 Posters 2.0k Views
  • E Offline
    E Offline
    eriondt125r
    Hey guys i recently fully rebuilt my dt125r new conrod new trans bearings new piston new crank side bearings and everything in the engine, now im thinking of doing some mods i have a 57.15 bore stock carb and other things stock i have a unrestricted cdi i think it was 3nc-00 or something i forgot now im thinking of buying the zeeltronic ignition system and powervalve system and maybe some carbon reeds with or without the spacer any suggestions ?
    • MadGyverM Offline
      MadGyverM Offline
      I liked the Boyesen dual stage reeds,the gave me a very angry kick at the powerband.
      Switched to a read cage of YZ125 after.
      Dep exhaust at 32mm widened at the port.
      Port tuning I would say is a must.
      E 1 Reply Last reply
      • MadGyverM MadGyver
        E Offline
        E Offline
        eriondt125r
        @MadGyver can really do port tuning anywhere on my country but what about those reeds what is you opinion and is it hard to adapt
        • MadGyverM Offline
          MadGyverM Offline
          The Boyesen dual stage reed bolt on to the dtr reed cage. The stopper is removed and no mod required.
            E Offline
            E Offline
            eriondt125r
            @MadGyver what about the yz reed cage are you happy with it or should i just go with only the boyesen reeds
            MadGyverM 1 Reply Last reply
              You can go one step further and fit the entire VForce4 Reed Block assembly.
              https://dt125r.co.uk/topic/2914/vforce4-reed-block-upgrade-yamaha-dt125r-re-x
              Zeeltronic and Exhaust made the biggest changes to me.
              I never got on with the port tuning if I'm honest.
              And the one thing I've grown to appreciate is the Athena Big Bore kit. It took a long time to appreciate it, but when you accept the DTR isn't an RS 125, then having the extra CCs and drop in overrev, actually suits the DTR nicely.
                E Offline
                E Offline
                eriondt125r
                @Calum i was looking forward to the zeeltronic but it costs 450€ on ebay to germany i think its a bit too much and as for the athena kit i heard that you have to modify the cases a bit to fit it and i dont want to ruin the cases bc if the cylinder goes bad at some time then i cant reuse the old one, btw what carb were you running eith the vforce
                • R Offline
                  R Offline
                  Rallyfinnen
                  I would re-machine the head first to a 'proper shape' and squish, possibly raising compresson a little. Depending on what shape the head has now, it can make a significant improvement.
                  Change the pipe and re-jet to suit the pipe and modified head.
                  You can also play with ignition timing with the stock CDI with offset keys, or possibly by filing the holes a bit to rotate the stator plate. Easy to get too much advance with the offset key I suspect, but I have seen dyno charts of it giving good results.
                  The reed will probably not make any significant difference with a near stock setup, you could cut some reed petals from some 0.3mm carbon reed material (I use Polini). Leave the reed stops in in this case. 0.3mm should be ok for the revs you are likely to acheive, and should improve bottom end and throttle response a tiny bit. Going too thick will give you less midrange and throttle response and more pressure drop over the reed (bad -less power).
                  I do like the Zeeltronic, but you need to be a bit of a nerd to fiddle around to get the tuning right, and it should be done on a dyno. 'Butt-dyno' works pretty well once you learn, at least for power valve to pipe adaptation, but the fine tuning of the ignition is better done on a dyno to make it good AND safe. In the end you will be rewarded with better power (and wider/smoother power band) and better throttle response.
                  • R Rallyfinnen
                    E Offline
                    E Offline
                    eriondt125r
                    @Rallyfinnen i have a 3bn head if im not wrong which is not restricted but one time i got it too hot and had to machine both the cylinder surface and cylinder head by .10mm .20-.30 mm in total so im runing a 1mm base gasket now as i didnt have time to check for squish, probably with open up on winter and check squish with solder wire and and change base gasket as needed to get the recomended squish to run on high octane fuel, btw i got a athena silencer on its way, im thinking of getting a athena pipe too as its easier for me to get a hold of as i know a guy who has a wrecked dt125r with a athena pipe as i could identify it. But what about the zeeltronic tho is there any way i can find it cheaper either for germany, switzerland , or kosovo somehow
                      You don't need to modify the cases to run the Athena 170 kit. Not sure where you've gotten that from.
                      The 3BN is the restricted head, 3MB is the non-restrictive head.
                      You don't really need to faff about with dialing in the Zeel as it comes with 5 maps that they've tuned. Of course to maximise the performance then yeah, you need to dial it in. But it was one of the single most performance increases I noticed.
                      • R Offline
                        R Offline
                        Rallyfinnen
                        Check ebay etc for used Zeeltronic maybe, but new that is about the price you have to pay.
                        Adding base gaskets will increase your port timings, maybe not a bad thing though, but an extra base gasket is a significant change on transfer duration.
                        You can weld and machine the 3BN head or get another one, but you will probably have to machine the other head too, to get a decent squish.
                        I have the Athena pipe, and it's better than the original (especially if the original is restricted), but also louder.
                          E Offline
                          E Offline
                          eriondt125r
                          @Calum im not really sure i will have to check but it didnt have the little step all around like a wall as i remembered the restricted one had i saw some photos as for the athena maybe it will come later on the way now im thinking of new crab v force reeds and the zeeltronic if i find it with a bit more reasonable price
                          • E eriondt125r
                            MadGyverM Offline
                            MadGyverM Offline
                            @eriondt125r
                            The YZ reed cage was used because it suited better my setup.
                            Dropped my max rpm, widened the power band. It's a more civilized bike now.
                            An 170kit as is,with a tuned or aftermarket reed valve,an after market exhaust and a programmable CDI (zeeltronic or ignitech) will make a whole new bike and an 70-80% of the second route.
                            The other route is from ground up build and tune almost everything in the engine and not only.
                            A lot of reading, searching, calculations, note keeping, machining, adjusting, combining info/parts.
                            Will give you a bike like what you see from a specific Portugal tuner, but with more money, time and headaches spend in the end.......knowledge is a side-effect bonus.
                            I will not recommend this torment to you , get the first choice.
                              @eriondt125r
                              E Offline
                              E Offline
                              eriondt125r
                              @MadGyver yeah as for now those are the things im considering as i use the bike for enduro too and im planing on later on to leave it only for road use and get it more snapier on throttle and power, rn just thinking of plans i got a idea of lightening the flywheel too for better rpms as it will lose a bit low end torque but for road use thats okay, so yeah a vforce4 a bigger carb maybe 30mm, zeeltronic setup and a bit setting up squish and cylinder height as i dont have a bigg budget things will he coming up slowly and would like for everyone who sees this to bring their ideas and i will hopefully keep you upt with the project
                              • MadGyverM Offline
                                MadGyverM Offline
                                @eriondt125r
                                Leave the flywheel alone. The TM28 is ok, DT200R uses the same with different jetting,so it's up to the task. Adding a power jet is a bonus if doesn't have integrated.
                                Squish is ok and already needs minimum 96 octane as Athena mentions.
                                I tempered with squish,height and combustion dome and now needs minimum 99+ from a good gas station, otherwise pinning heavily. Doesn't worth with gas prices.
                                I plan to lower the compression and dome shape so be able to run 91 octane gas.
                                  @eriondt125r
                                  E Offline
                                  E Offline
                                  eriondt125r
                                  @MadGyver im talking about the stock 3mb-00 cylinder asn the stock cylinder head i want to modd them for higher octane fuel for ex like 0.9 0.8 if its possible or a bit higher than the lowest safe squish and as for the carb i will maybe switch to another with the extra jet and the reeds, btw are you running 170cc kit or stock and if so did you feel a diference at power when adding work on the head dome and squish
                                  • MadGyverM Offline
                                    MadGyverM Offline
                                    @eriondt125r Running an engine where only the crankshaft is stock and fitted with 170cc kit also tuned.
                                    The head tuning was done for fuel efficiency then power delivery in mind when gas prices where lower.
                                    Both where achieved at a cost.
                                    10lt (main tank,didn't measure the reserve) for 260kms up to 7k rpm,screaming bike up to 11.5k.
                                    Power/fun yes.
                                    Usability not so much, I have found only 2 gas stations out of 15 with in 20km radius from where I live,that have the appropriate fuel quality and 100 octane gas.
                                    A tuned 3MB head+cylinder is fun and quick. better than a stock 170 kit, overall no.
                                    A very tuned 170 is another level,between a stock 3ET and 3XP,dare to say.
                                    • R Offline
                                      R Offline
                                      Rallyfinnen
                                      Found this when looking for a Zeel:
                                      https://www.motoracingshop.com/en/unit-zeeltronic-pcdi-10vt-dt125re-x-de06-con-programmable-ignition-power-valve-controller-for-dt125x-re-de06-with-plug-and-play-connector.html
                                      • R Rallyfinnen
                                        E Offline
                                        E Offline
                                        eriondt125r
                                        @Rallyfinnen sadly doesnt fit mine i have a 4bl engine with 3nc-00 cdi 3 wire servo https://imgur.com/a/MCqdDEW
                                          Power/fun yes.
                                          E Offline
                                          E Offline
                                          eriondt125r
                                          @MadGyver have a carb in a trade now a brand new mikuni tm30 with powerjet and some carbon reeds im thinking of doing that as for now what do you guys say
