  3. DTX
  4. Jetting the carb
Jetting the carb
31 Posts 4 Posters 4.0k Views
    Was it doing this before the exhaust change?
    • Elan nE
      Elan nE
      Elan n
      @calum @hotshot-iii yes i did a full carb clean, took everything apart and cleaned it and i dont know, the seller told me it drives good and gave the original exhaust with the bike too. I also ordered an fully overhauled carb to replace it. Came in today and dontacted the seller from the exhaust and told me to use a 245 jet but havent tried it yet. Tomorrow im gonna install everything back
      • R
        R
        Rallyfinnen
        You should get a set of main jets and go up in size significantly until it runs too rich, then start going down until you find the sweet spot. You might need to raise the needle too if it bogs when you twist the throttle. You will probably notice problems when running abt half throttle if the needle is wrong. Keep an eye on the plug when you are jetting, if you have some experience in jetting, the feel and sound of the engine will tell you when you are close. I sometimes use Chinese jet kits and think they work ok, especially for the price, but you can't compare the numbering on them with anything else, you have to stay with that kit when you are jetting.
        • Elan nE
          Elan nE
          Elan n
          @rallyfinnen installed the overhauled carb, tried a whole lot of jets and ended with 210 but now it suddenly runs really bad, cant get past 4k rpm because it stutters really hard, sounds like a rev limiter.
          • R
            R
            Rallyfinnen
            Then I guess it's ignition related, might be hard to find the problem..
              Are you using a genuine coil?
              I had something very similar with a Chinese 'race' coil. Took me absolutely ages to get to the bottom of as I rebuilt the whole bike from the ground up and the coil was one of an assortment of new parts.
              So I am very wary now of aftermarket coils.
              • Elan nE
                Elan nE
                Elan n
                @calum found the problem, servo cable snapped so the powervalve didnt work properly.
                • Elan nE Elan n
                  @Elan-n You can make your own using stainless MTB gear cables, use the inline cable oilers as well and you can quickly re-lube them after every wash:
                  https://dt125r.co.uk/post/28693
                  • Elan nE
                    Elan nE
                    Elan n
                    • Elan nE
                      Elan nE
                      Elan n
                      @calum @hotshot-iii @rallyfinnen All right! But so abaut the jetting, so i should have no restrictions on my 2006 dtx. The only upgrades that i have are the reeds that were switched to carbon ones and a spacer between the intake and the reeds. and also the purtagal pipe from romeuhenriques. Current jetting is: idle 17.5 and main 210. Am i supposed to follow the older model with the 240 jets or what should i start with?
                        Go with the 210 main jet, do a plug chop and adjust to suit.
                        The CDI on the 2006 DTX (at least in the UK) is restricted. So you won't be getting full power until you derestrict it, even then the performance is still stifled.
                        Biggest upgrade I noticed to overall performance was a Zeeltronic ignition system.
                        Vastly improved the performance on my DTRE.
                        • Elan nE Elan n
                          @Elan-n Agree with @calum about the Zeeltronic, I enjoyed the process of installing mine and making it look as stock as possible.
                          Re jetting, I think I'd be contacting Romeu Henriques, tell him about your other mods (intake spacer dimensions etc.) and see what he says. Everyone speaks very highly of his exhaust systems so he will probably have enough knowledge to plug the numbers into some two-stroke tuning equations and help you out.
                          • Elan nE
                            Elan nE
                            Elan n
                            @calum @hotshot-iii all right, i contacted the seller of the exhaust and he told me to use 245 main jet. So ill try that first. After some time ill get that zeeltronic. Firstly i want to get safely on the road. Piston replace gotta happen too because my piston has 22k kilometers but stil sounds good tho no ratlling or something but i want to be sure
                              #PotentialHandGrenade 🤣
                              https://www.youtube.com/shorts/0KlaU_adlWg
                              This was the state of my Raptor piston prior to me rebuilding it. Engine was running absolutely tip top prior to dismantling it. But this was a literal ticking time bomb.
                              • Elan nE
                                Elan nE
                                Elan n
                                @calum damnnn thats indeed a mayor problem haha, today im gonna remove the reeds and sparkplug and inspect the piston and cilinder walls with an endoscope
                                • Elan nE
                                  Elan nE
                                  Elan n
                                  I searched with an endoscope in the intake an sparkplug hole and damn everything looks mint. How is that even possible haha.
                                    Well, the Mito engine is highly strung. The Mito runs rings around the DTR, but as a result they're a lot more fragile.
                                    I had the same thing with my ETX, absolutely battered bike, but it's in such a low state of tune that the engine was crisp, almost criminal to rebuild it.
                                    • Elan nE
                                      Elan nE
                                      Elan n
                                      • Elan nE
                                        Elan nE
                                        Elan n
                                        wrote on last edited by Elan n
                                        #23
                                        @calum @hotshot-iii okay a lott happened in the meantime. Firstly i fixed the servo cables and after cleaning procedure it aligned perfectly with the hole. Looked in the exhaust port and was correct. Removed the spacer but kept the carbon reeds. Still runs like crap en servo moved weirdly, not correct in my opinion. That aside, still stutters right before powerband. With as well the 210 and 17.5 jetting and 240 and 27.5(French setup )but with the higher jets i had a lot better throttle response and idling. With the richer setup i tried it to pin the pv on the open position to see what it does when i hit the powerband. And finally it hits 🙂 but only in first year tho :s the other gears is starts stuttering again.
                                        Checked my deristrictrion and everything was like its supposed to. So yeah im out of ideas now haha, i run a br9es also like im supposed to. Checked for air leaks, no leaks present. Cleaned air filter and oiled it correctly. Also of i compared the original mikuni jet 210 with the new 240(also a real mikuni) the hole on the 210 was bigger??
                                          So I don't align the powervalve with the hole (partly because my exhaust/valve have been ported so it probably isn't right anyway. You did right by aligning flush with the exhaust port. I'd just focus on that, take the exhaust off and align it with the exhaust port. Flick the ignition on and off a few times to make sure the cables don't realign.
                                          If you want a quick way to diagnose your problem to get you a steer in the right direction then I'd do this.
                                          1. Align the powervalve flush with the exhaust port
                                          2. Disconnect the powervalve servo
                                          3. Remove the carb air filter boot (eliminating the airbox)
                                          4. Run the bike with no air filter
                                          What this should do.
                                          Remove the powervalve will stifle bottom end, but 6k+ should shoot off like a rocket.
                                          Eliminating the airfilter removes any restrictions that might be present in the air intake tract. Whilst not ideal running without a filter, it will be fine for a short space of time. Unless a stone flicks into the inlet you'll be fine.
                                          You should now be running the bike quite lean (so avoid prolonged wide open throttle). The bike should run better now than ever.
                                          If it runs worse, it tells you your jetting is too rich. If it runs better then you know that you need more fuel. If it runs the same, then you know the problem lies elsewhere.
                                          I am expecting it to be the latter, I'm expecting the problem to lie else where, but ruling these items out first, means we can then start to go more technical knowing that we've addressed the simple things first.
