Derestricting a DT125RN (4BL, 1997) Looking for advice before I buy
Hi all,
I'm looking to buy a Yamaha DT125R and I've found one, but it's a DT125RN, model code 4BL, from 1997. I've heard this version is restricted to 80 km/h.
Does anyone here know how to derestrict this specific version? What exactly is limited on the 4BL (exhaust, carb/jetting, ignition/CDI, power valve, intake), and what needs to change to remove the restriction?
Also:
- Which parts are needed, and are the originals still available?
- Any problems to watch for after derestricting (jetting, reliability, piston/cylinder)?
- What should I check before buying the bike ?
Photos of what to look for would be a big help. Thanks in advance!
Lot's of information on this site already.
I find going to
Googleand usesite:dt125r.co.uk 4bl derestrictionbetter than the internal search.https://dt125r.co.uk/topic/3102/derestrict-yamaha-dt-125-r-1997/66?page=4
It does depend on what region you live in, but the easiest way to get full power is
- Zeeltronic Ignition
- DEP Pipe
Make sure you've got
3MBcylinder head (3BNdenotes you've got a combustion ring head that benefits from machining out). But otherwise you'll be laughing! -
I find going to
- DEP Pipe
