  3. Need a speedo drive
Need a speedo drive
6 Posts 3 Posters 2.3k Views
  • 8 Offline
    8 Offline
    8ig_bad_st3v3
    Hi is anyone aware of any other speedo drives from other bikes that will fit a dtr125 (1990)
      Plenty of them about on the bay
      http://www.ebay.co.uk/itm/131968239314
      8 2 Replies Last reply
        8 Offline
        8 Offline
        8ig_bad_st3v3
        @Calum Was just asking if the same part was used on other bikes. as parts listed for the dt are expensive. The equivalent part for a ybr125 is only £20 new. The dt is £35 second hand
          8 Offline
          8 Offline
          8ig_bad_st3v3
          Cheers anyway tho bud
          • 8 8ig_bad_st3v3
            @8ig_bad_st3v3 Check.thepart number to see if they are the same.
            I would suspect that this may be so. The forks are going ti be very similar spec.to the dt.
            • tunertomT Offline
              tunertomT Offline
              tunertom
              https://www.ajsutton.co.uk/product/yamaha/3XP251900000/gear-unit-assy?uid=0
              go here... go to the tab that says fitment, it shows the part number and all the same bikes that use the same speedo as the DT.
