Athena 170cc questions
Pinned valve doesn't perform well.
I'd put the standard carb back on and see how it runs with rejetting. I converted my 125r to 200cc. I run a tm34ss carb . And my dt200wr has the standard tm30ss (almost identical to the tmx30) both are good carbs for the bikes.
I did run a tm32 which never ran that well -
Its always ran better pinner electric pv just not very good on old ones on my newer one 2001 is fine with electric pv and i was using origanal tm28 carb it didnt like that with 170 kit
@jackreece show a picture with your tm32 installed. The float bowl needs to be pretty level. Because of how the DT engine and intake is, some carbs will sit at a angle
