  4. Athena 170cc questions
44 Posts 10 Posters 12.7k Views 1 Watching
  • Irongamer727I
    Irongamer727I
    So yesterday I got my Athena kit.
    1st question: How do I separate the powervalve? I have unscrewed the bolt holding the 2 sides but it won't come apart. Don't won't to mess with it too much. Any ideas?
    F 1 Reply Last reply
    • Irongamer727I
      Irongamer727I
      ![0_1506071846781_20170922_110547.jpg](Uploading 100%) 0_1506071855557_20170922_110534.jpg 0_1506071863188_20170922_110527.jpg
      • Irongamer727I Irongamer727
        @irongamer727 just tap it with something that's not gonna dent it
          F
          F
          Feca126
          @irongamer727 you don't need the old valve, you only need the valve holder, pls read athenas instruction https://www.google.hu/url?sa=t&source=web&rct=j&url=http://www.athenaparts.com/files/pdfs/P400485100010-P400485100019.pdf&ved=0ahUKEwjOiLi1u7jWAhWGWxoKHctRAfgQFghEMAo&usg=AFQjCNEB4zQP67rDA0hu4MGkfZoWMnyPZg
          • F Feca126
            Irongamer727I
            Irongamer727I
            @feca126 what? This is the new valve that came with the kit?
            • Irongamer727I
              Irongamer727I
              Allright. Question 2. In the manual that came with the kit(which you can find in the link) it says "reuse the valve support bushing. Be careful: the cylinder bushing with original p/2rl cannot be assemble into the Athena kit, therefore you must buy the original bushing 31k-1131U-00" What do they mean? Can I reuse the bushing or not?
              • NottsbikerN
                NottsbikerN
                2RL is a TZR code and i think it's for the 6 sided cylinder unique to the steel framed 125's
                • Irongamer727I
                  Irongamer727I
                  Is it necessary to go for 3% oil mix? Thinking about just tuning the oil pump a bit
                  Heard about many people who still drives with the pump with this kit
                    Jens Eskildsen
                    I think the oil pump should be able to add sufficient oil, using a half-decent oil.
                    Many enduroriders on 300 2-strokes use way less than 3%
                      It's a good point though.
                      It is a bigger CC and the pump was only designed for a 125.
                      Pretty sure my brother ran with stock oil pump settings no problems.
                      • F
                        F
                        A guy on the YOC had one in his TDR, ported and tuned. Did 30 odd thousand miles before the gearbox blew up!
                        • F finnerz89
                          @finnerz89 Jeez, is YOC still going?
                          I haven't logged on in ages. Used to be great back in the day.
                          30k miles isn't a lot, especially considering these boxes are straight cut.
                            F
                            F
                            @calum decent amount for the 170 kit though?
                            I don't know exactly what went wrong with the box, but it stopped selecting gears so probably bent selector forks
                            • F finnerz89
                              Irongamer727I
                              Irongamer727I
                              @finnerz89 why would the 170 kit affect the gearbox ?
                                @irongamer727 More torque than what was initially designed.
                                The box is pretty over compensated on these bikes, I'd still say 30k is low.
                                I suspect the bearings failed, which in turn damaged the box. I'd expect that to happen. Again if the bottom end was rebuilt as per maintenance then that would have been avoided.
                                It's the first I've heard about gearbox going due to the Athena kit.
                                With that in mind, I shouldn't worry too much.
                                • Irongamer727I
                                  Irongamer727I
                                  Allright. Every part has arrived. Now. Once I installed the kit and put a big main jet and lowered the needle(more fuel). Should I start it and ride 500 km with the settings way off?( way to much fuel) Or should I lower the jetting until he rides okay? Thing is I don't won't to put any stress on him when the kit just has been installed. How would you do?
                                    @irongamer727 sorry I know you are asking important questions but did you just refer to your bike as a “him”
                                    declanD O 2 Replies Last reply
                                      @declan and personally no I’d adjust the oil pump to run more oil which is what me and @Calum currently already do
                                        @irongamer727 You're going to want to ensure you jet it properly and ride it accordingly.
                                          @calum is he not planning on jetting it?oh I see just by banging a main jet in don’t necessarily mean it’s correct as all bikes are different and it’s a pretty precise task
