  3. Exhaust
  4. Baffle inside dep end can?
7 Posts 3 Posters 4.3k Views 2 Watching
  • D Offline
    dan28
    Just bought a used dep end can cut it down to stubby it
    An found there is no inner pipe ( baffle )
    I thought this was welded in
    Has someone removed it or do some pipes not have one
      Should be a long perferated tube surrounded by wadding inside the end can.
      • D Offline
        dan28
        It's empty no wadding or pipe inside
        • DartyD Offline
          DartyD Offline
          The baffe is not welded into the Dep end can, It just sits over the exhaust pipe which protrudes into the end can a touch. A bit odd why this is gone, It's useless without it. The baffle is nothing special, you could roll some perforated steel, or thick mesh. I don't recommend cutting down the original Dep end can. Nothing to gain except noise.
          An old school 88-92' YZ/CR FMF end can fits all right, there much easier to service as well.
          • DartyD Darty
            @Darty agree with Darty here!
            I went custom yo!
            Bought a nice Carbon Fibre Jolly Moto End can for an Aprilia rs125 and fabricated that.
            • D Offline
              dan28
              I think I should be able to fit the baffle from my big one exhaust in to the dep
              The Dt engine isn't in a Dt an the shape of the dep gives more room
              • D dan28
                @dan28 yeah that's fine. I can use my jolly moto on any expansion chamber.
