  4. Engine bogging in 6th gear??
5 Posts 3 Posters 2.8k Views 1 Watching
  • L Offline
    L Offline
    Lewisf5755
    Hi I'm new to this site and have just got myself a 2001 dt125r the bike is in great condition and I'm really enjoying it so far. I have a slight problem the bike has been fully de restricted, the power valve is set up properly and working a treat. I can see under the clocks the cables have been cut and joined and it has had a full dep exhaust put on. It goes through the gears lovely up to 5th (doing about 100kmp) as soon as I put it into 6th the engine sounds as if it gets deeper and bogging. The bike then starts to loose power and speed as soon as I go back to 5th it's perfect again. Can anybody help me on this as I'm really stuck?
    Many thanks
    Lewis
    DartyD 1 Reply Last reply
    • L Lewisf5755
      Many thanks
      Lewis
      DartyD Offline
      DartyD Offline
      @Lewisf5755 Yo yo welcome.
      Might be your sprocket sizes first, sounds very similar to my old setup. Had a small sprocket on the front which really limits the available torque into 6th on anything but a long flat road.
      • L Offline
        L Offline
        Lewisf5755
        What sprockets did you have? Do you know what ones I would need? Thanks
        • L Lewisf5755
          DartyD Offline
          DartyD Offline
          @Lewisf5755 16T Drive sprocket and 57T rear are Original spec. Very good standard gearing, I liked it on the road.
            Thank you Darty! That would have been my first point of call!
