  3. Brakes
  4. Brake problem
Brake problem
4 Posts 2 Posters 999 Views
  • B Offline
    B Offline
    Bananper
    So yesterday i was out riding, i parked my bike for like an hour and when i came back there was no resistance on the rear brake, no pressure. When i came home i bled the rear caliper and topped up with brake fluid, and then i noticed that the piston wouldn't move more than 0,5cm (about 0,18 inches?) There is no resistance when i push the pedal whatsoever, so i guess it may be a leakage? Is this common on the DT's? Any ideas?
    • MiniaM Offline
      MiniaM Offline
      Minia
      Sounds like your brake fluid is leaking, guess you'll have to find the leak and fix it. When you pumped the pressure up did the piston move all the way? Did you notice a leak anywhere?
      B 1 Reply Last reply
      • MiniaM Minia
        B Offline
        B Offline
        Bananper
        @Minia no thats the problem it doesn't go all the way
        MiniaM 1 Reply Last reply
        • B Bananper
          MiniaM Offline
          MiniaM Offline
          Minia
          wrote on last edited by Minia
          @Bananper Check all your lines and look for evidence of a leak, if it isn't from your master cylinder or hydraulic lines then dismount your brake caliper and check it over.
