  2. Tutorials
  3. How to Supermoto a DT, using donor parts from other Yammy's
Scheduled Pinned Locked Moved Tutorials
1 Posts 1 Posters 2.4k Views
  • NINJAN
    I found this on the old forum, so I thought that I would re-post it here for general info;
    Both the TDR125 and TDR125R will donate their parts for the DT125R Supermoto conversion with no mods , bolt on and ride!!
    The parts you need for the conversion from both bikes are as follows
    Front forks, NOT THE YOKES OR CLAMPS from 90-91 models
    Front wheel, wheels spacers , speed cable and speed drive
    Complete front brake including the caliper bracket for the fork leg
    Rear wheel and disc,
    IF YOU USE THE TDR125R PARTS YOU NEED THE SWINGARM TO COMPLETE THE REAR BRAKE SYSTEM AS WELL
    The DT125X will also donate parts , you will need the following
    Front forks , NOT THE YOKES OR CLAMPS from 05-06 models
    Front wheel, wheels spacers, speed cable and speed drive
    Complete front brake system and caliper bracket
    Rear wheel and disc
