  4. Stators keep dying on my dt
2 Posts 2 Posters 688 Views
  • B
    B
    Bananper
    So my dt stopped sparking, and after a lot of fiddling around i found the source coil to be weak, so i bought another pre owned stator and put it on the bike, fired right up and i drove it around and suddenly the bike died. I measured the ohms on the source coil it was 88 ohm, should be 192-288.
    So my question is, is there anything on these bike that could kill the stators like this, or am i having bad luck with the pre owned one i just bought.
    Any suggestions or opinions is greatly appreciated!
      I don't think so, stators are self regulating.
      I don't know the internal workings of one.
      But an alternator uses battery power to generate power. But the DT uses a generator, so no battery power is needed.
      So for example, if a high load is demanded on an alternator, it could wear it out, but I don't think that's true for a generator. I don't know....
