  3. How to adjust the power Valve
5 Posts 2 Posters 2.0k Views
  • DTleeD
    DTleeD
    DTlee
    Hello all,
    I’ve been looking at a few bits in here about adjusting the power valve so it’s flush To give it more power but I cant find any where that explains how to do it. I’ve taken my exhaust off and can feel that it’s not flush. So where do I go from here? Are there any guides or pictures?
    Thanks in advance
    Lee
      It's pretty simple.
      There are two cables that attach itself to the powervalve housing.
      Undo the locking nuts, adjust the cables with a spanner. Get it so that when you turn the ignition on and off the port is flush.
      Tighten the locking nuts. Take her for a spin 😃
      • DTleeD
        DTleeD
        DTlee
        Ah it’s that simple I was overthinking it then. Thought there must be more too it
        Cheers
          Nope. Just make sure the valve is positioned in a known location before you start making the adjustements.
          Either fully open or closed.
          I prefer fully open personally.
          Adjust accordingly, then cycle the powervalve to ensure it's correct, before tightening all to spec.
          • DTleeD
            DTleeD
            DTlee
            Thanks mate
