  4. DTR throttle cable help!
2 Posts 2 Posters 701 Views
  • P
    P
    perky
    Hi all im fitting the original autolube pump to my 2006 DTR and need a new throttle cable as the cable that goes to the oil pump is missing, will a cable from a 1998 fit this is the only one I can find an help apreaciated thanks
    K 1 Reply Last reply
    • P perky
      K
      K
      kevin
      @perky there are two types be careful, one has a round splitter box and one is oblong that is the later one, the problem arises when the oil pump cable goes into the housing and you try to fit the retaining clip and it’s the wrong length.
