  3. Unburnt oil from ypvs Left side help
2 Posts 2 Posters 923 Views
  • W
    W
    waale2004
    I have a dtr 03 model fitted with Athena 170kit, Athena exhaust and 32mm flat side. And I keeps coming unburnt oil out of the power valve on the left side where the cables go in. I have a 122 jet now and before that i had the original carb with 300 jet at it just keeps coming oil. I have even tried changing all the o rings and seals on the powervalve but after a few rides I just keeps coming. I am also riding with 2% oil mix
    • S
      @waale2004
      You changed the seal as well as the o~rings. I don’t know if the Athena kit uses special or standard parts? 2 o~rings & 1 bush seal. These are the only parts that can be a problem...
      Do you premix 50:1?...
