  3. I have just bought a dt125r 1999 model. I'm mixing my own fuel. Can I put the same oil in my engine as I'm putting in my fuel tank?
4 Posts 2 Posters 1.4k Views
  • S
    shanedalton
    I have just bought a dt125r 1999 model. I'm mixing my own fuel. Can I use the same oil what I'm using in my fuel tank and put it in my engine? Thanks 😊
    markus.wM 1 Reply Last reply
    • S shanedalton
      markus.wM
      markus.wM
      @shanedalton no you most certainly can not. Use 2 stroke oil to mix with the petrol and make sure that it's compatible for premix as some are specifically designed for autolube/oil injection pump only and they won't break down and mix properly. If in doubt as to the ratio use an online premix calculater. As for the engine/gearbox use either silkolene or putoline light gear oil. It's all very critical as if you get it wrong you'll be looking for an engine rebuild very soon.
      S 2 Replies Last reply
      • markus.wM markus.w
        shanedalton
        @markus-
          shanedalton
          @markus-w Thank-you much appreciated. It has been 30 years since I had one!
