  3. No break lights
No break lights
2 Posts 2 Posters 1.1k Views
  • primal carnageP Offline
    primal carnage
    So bikes looking mint done full re build new paint job graphics bairngs the works im now on with the break lights none are working at all ..does come on a bit when bike is running indecators are fine does this sound like a break in the line somewhere
    • primal carnageP primal carnage
      @primal-carnage
      If it comes on ‘a bit’ it may be a bad earth at the tail light. Is it the same with back and front brake levers?
      Also have you changed to LED lights anywhere?
      The brake light should work off of the battery without the engine running…
