  3. DT125 re wheels conversion issue
4 Posts 2 Posters 1.9k Views
  • J Offline
    J Offline
    jarvis2292
    Hello, so I am new to this forum and i hope this is okay to just start here but anyway, So I have a yamaha dt125 re which has dt125x wheels on it and I am just wondering if the yamaha wr125 or yamaha dt125r wheels (struggling to find dt125re wheels) fit straight on without hassle.
    Reason being is the front calliper isn't making full contact with the disc break and would rather just go back to standard as possible with it.
    Thanks for reading
    markus.wM 1 Reply Last reply
    • J jarvis2292
      Thanks for reading
      markus.wM Offline
      markus.wM Offline
      @jarvis2292 the dt125r and dt125re are identical wheels, 18" rear, 200mm disc and 21" front, 230mm disc. The X model is 17" rear, 200mm disc and 17" front, 298mm disc twin pot caliper.
      J 1 Reply Last reply
      • markus.wM markus.w
        J Offline
        J Offline
        jarvis2292
        @markus-w okay thank you for that, i thought they would be the same. Do you know whether the wr125 wheels are the same also?
        • J jarvis2292
          markus.wM Offline
          markus.wM Offline
          @jarvis2292 they will fit also.
