  4. 4BL Oil Pump Settings
4 Posts 3 Posters 981 Views
  • D
    dominik22
    Hello Guys and greetings from Germany πŸ™‚
    i am currently in the process of rebuilding my 4BL and cant find the correct Setting for the Oil Pump.
    Some say the Lines should match up on closed throttle, some say they should match up on WOT.
    Sadly i cant find the Haynes manual in Germany anywhere.
    Maybe someone can help me here
    • D dominik22
      Stevie WonderS
      Stevie WonderS
      Stevie Wonder
      @dominik22 alt text
      • Stevie WonderS
        Stevie WonderS
        Stevie Wonder
        It’s in English but it might help. I know you can get German owners manuals which could be of use to you.
          @dominik22 I take it your pump is not the plunger type?
          https://www.youtube.com/watch?v=WwFUzgr2xnA
          This is how I set my pump many many years ago. I did not align the lines intentionally just to run a fraction more oil due to the porting work I was running at the time.
