  4. Powervalve ‘squeeking’
3 Posts 2 Posters 280 Views
  • D Offline
    DTGREENLANER
    ![What’s causing my DT125RE Powervalve to make these noises and how do I sort it? Is the servo on its way outt
    Was working fine the other day
    Powervalve seems to be operating fine, just got 2 different nasty squeek when turning ignition on and when pulling away
    Notice the 2 different types of the “squeeking” in the vid
    link text
    https://streamable.com/717lam
    Cheers
    • D DTGREENLANER
      link text
      Cheers
      @DTGREENLANER I'd say that's a dry bearing inside the servo somewhere, I think they can be taken apart and the gear train serviced. Never done one myself but it's pretty much a scaled-up RC car servo, just take your time and lay everything out in the order you removed it and you should be all good. Southeast Asia is full of DTRs, DT230 Lanzas etc. and some of those guys repair the servos quite often.
      • D Offline
        DTGREENLANER
        Sorry for late reply
        Thank you
        We carefully took it apart and greased it back up and running nice now, the bike is so much more responsive and acceleration is a lot better
