  4. Ouch
Ouch
9 Posts 3 Posters 1.9k Views
  • C
    C
    castrolsniffer
    wrote on last edited by castrolsniffer
    • C castrolsniffer
      @castrolsniffer 😬
      • C
        C
        castrolsniffer
        Just taken this outta my nephews dtr all that sharp metal is the rollers themselves all smeared into each other.
        I think it was grit sucked in from a badly sealed air filter as the piston has little scratches on the intake skirt but I do know the bike wasn't run in by the previous owner and only had 400 miles on a fresh full rebuild 😨
        Any thoughts?
        • C castrolsniffer
          Any thoughts?
          @castrolsniffer perhaps when it was rebuilt the crank was neglected and needed changing?
          • C
            C
            castrolsniffer
            No was brand new crank,I know the previous owner and where he had it done 😔
            He didn't buy cheap either,everything was mitaka,genuine gaskets and seals,oil pump checked and adjusted £££££ 400 miles bang,big end bearing failure but not 100% sure why
            • declanD
              Not that I know much but looks heat related to me like something caused friction?
                Yeah that's a lack of oil that is bud.
                • C
                  C
                  castrolsniffer
                  I thought that too but the piston is fine so not 100%convinced,I thought the piston would suffer first as it's hot and the crank splashes thru a little puddle of oil in the crank cases.
                  That's why I'm asking tho guys,any input welcomed 👍
                  • C castrolsniffer
                    @castrolsniffer Nah check the oil galleries in the crank case bud.
                    Yhr connecting rod will have oil galleries as well. It clearly hasn't gotten to the big end.
