    • Register
    • Search
    Power Valve set up
    Technical Zone
    4
    4
    821
    Loading More Posts
    • A
      AnthonyPearson last edited by
      When setting up the Servo/Pulleys on my DT, i understand it is necessary to ensure that the powevalve is flush with the exhaust port.
      I have taken off the exhaust have ensured that this is the case, take the slack off the cables, and turn the ignition on so it can do its cleaning cycle.
      When i do this the servo makes the noise it would if it was trying to move but it gets stuck.
      When it does the Cleaning cycle, the powervalve turns clockwise and and pins shut, is this normal behaviour, as when i hit 7,000 where the PV should kick in and throw the front wheel up there is just a small pull, nothing compared to what im used to.
      Is there something that i am doing wrong?
      Blue Yamaha DT 125R 2003
      • Calum
        Calum last edited by
        Well I wouldn't say throw the front wheel up, it's not a crosser.
        There should be no power drop off however.
        • Zrako
          Zrako last edited by
          Overtightened pv adjusters maybe , is your cleaning cycle nice and turns free?
          1979 Jawa Mustang 50
          2003 Gilera DNA 125 R.I.P
          2015 Keeway TX 125 SM
          2006 Yamaha DT 125 X
          declan 1 Reply Last reply Reply Quote 0
          • declan
            declan @Zrako last edited by
            @Zrako when I rebuilt my bike my servo would get stuck when turning on the ignition how ever I kept turning the key and it sorted its self out no problem
