  3. General a/f adjustment
3 Posts 2 Posters 933 Views
  • declanD Offline
    My other bike not a dt was running rich so I tried adjusting the air screw got it to nearly perfect maybe a little lean but after a bit the bike wouldn’t idle on its own so I re set the screw still nothing then backed it out and perfect again but then stopped idling and then started red lining I had to pull the plug that was with the screw almost all the way out needle clip in the slightly lean position anyone have anything to add?
    • F Offline
      F Offline
      Shouldn't the air/fuel screw and idle screw be separate?
        @finnerz89 yes they are
        With your input, this post could be even better đź’—
