  3. DTX
  4. DTX 125 PRODJECT
DTX 125 PRODJECT
93 Posts 10 Posters 43.4k Views 1 Watching
  • stinkwheelerS
    stinkwheelerS
    stinkwheeler
    wrote on last edited by stinkwheeler
    #31
    I also fitted some cheap chinese adjustable levers like an asv replica and there quite good for 15 quid odd to be honest I've had a set on my rs for a while... http://imgur.com/gallery/bJkW6be ...
    • stinkwheelerS stinkwheeler
      #32
      @stinkwheeler Looking good bud, BTW Royal Mail only holds stuff for 18 days normally, so you got lucky there!!! 😉
      BluestoesonnoseB stinkwheelerS 2 Replies Last reply
      • Glynn123G
        Glynn123G
        Glynn123
        I'm really wanting one of these underslungs for mine now!
        Got the regular MX design Romeu pipe and it's awesome, he makes some great work
        Liking the build mate
          BluestoesonnoseB
          BluestoesonnoseB
          Bluestoesonnose
          @NINJA
          I've got the Chinese adjustable levers, not my thing and would gladly swap them for a std pair
          2002 DT125R
          • NINJAN
            #35
            @Bluestoesonnose As cheap as chips;
            https://www.ebay.co.uk/itm/YAMAHA-DT125-R-DT125-RE-FRONT-BRAKE-CLUTCH-LEVER-LEVERS-2004-2007/302442220027?hash=item466af609fb:g:nsgAAOxydlFSqa97
            :grinning_face: :face_with_stuck-out_tongue_winking_eye: :smiling_face_with_open_mouth_smiling_eyes: :face_with_stuck-out_tongue_closed_eyes: :grinning_face_with_smiling_eyes:
              stinkwheelerS
              stinkwheelerS
              stinkwheeler
              @NINJA yea i was lucky its only because they didn't habe a return adress and it was parcel force it didn't go back i was really lucky and thanks mate it getting there 🙂
              • stinkwheelerS
                stinkwheelerS
                stinkwheeler
                #37
                Just polished the romeru pipe you can get the stainless up quite nice with a bit of elbow grease and some autosol ..... http://imgur.com/gallery/0HRcGQF
                I have now acquired a spare 3mb head and barrel to get bored / or not ..... ported polished blasted and powdercoated pics to follow ....
                3
                  @stinkwheeler Go on then, how long you spend doing that!
                  That's impressive. I've never been able to understand how you polish metals!
                    #39
                    @stinkwheeler Very shiny indeed, she looks beautiful. To keep her looking like that use this stuff to protect her;
                    https://www.ebay.co.uk/itm/ACF-50-ANTI-CORROSION-MOTORCYCLE-SPRAY-PROTECTION-ACF50-13oz-UK-Supplier-NEW/263262429739?epid=624178990&hash=item3d4ba9e22b:g:bdcAAOSw-zxWmiLY
                    (And you can upload images direct to the thread, just click the camera icon, select photo, click OK and then wait till it's 100% processed before posting).
                      stinkwheelerS
                      stinkwheelerS
                      stinkwheeler
                      @Calum i literally used blue roll and autosol and rubbed in in circles i did spend a good 3 - 4 hours though.... and im still not entirely happy i will do it again another once or twice before i put it on 🙂 and thanks ninja will give that a try 🙂
                        stinkwheelerS
                        stinkwheelerS
                        stinkwheeler
                        @NINJA will try that mate and i know i can do that with the images but it always says there too large and i have to spend 20 mins cropping them down to be small enough to add ....
                          @stinkwheeler :grinning_face_with_smiling_eyes: Just reduce the picture size on your camera, I always use 1920 x 1080 res and have NP's uploading any pics. 😉
                            stinkwheelerS
                            stinkwheelerS
                            stinkwheeler
                            @NINJA ^ thanks mate thats obviously where im going wrong spot on i did try for ages then gave up will bare that in mind for next time nice 1 🙂
                            • Glynn123G
                              Glynn123G
                              Glynn123
                              I wouldn't spend too long polishing, mine seems to bake an orange tint and blue at the cylinder end after a good thrashing! Looks awesome, really want an underslung now
                              • Glynn123G Glynn123
                                #45
                                @Glynn123 That's the heat affect, which is caused by the metal's properties changing due to the prolonged exposure to the heat being pushed through it. Which is more noticeable on welding seams as the weld causes the molecules in the metal to change slightly, which affect's the metals properties and causes discoloration in the ends of the metal pipes. Only a surface coating like chrome plating will hide those blue and orange tints for-sure, otherwise they will return as you have stated.
                                @stinkwheeler If you lowered the picture res to 1920 x 1020, you will also be able to store more pics on your camera, as each photo will take up less space on your memory card. 😉
                                Glynn123G 1 Reply Last reply
                                  Glynn123G
                                  Glynn123G
                                  Glynn123
                                  @NINJA yeah I didn't know the clever side to it haha, I just try polish ever couple rides to keep her shiny
                                    @Glynn123 Which exhaust do you currently have bud???
                                      Glynn123G
                                      Glynn123G
                                      Glynn123
                                      @NINJA got the Romeu hendriques upright MX type currently mate, it's a nice pipe 👌
                                        @Glynn123 Lovely pipes those, you should start a build thread bud and post some pics for us all to drool over!!! :smiling_face_with_open_mouth_closed_eyes: :smiling_face_with_open_mouth_cold_sweat: :face_with_tears_of_joy: 🤣
                                          @Glynn123 WOOPPPSSSSS!!! You already have;
                                          https://dt125r.co.uk/topic/1312/dt-125-re-supermoto-build/2
                                          :smiling_face_with_open_mouth: :smiling_face: :smiling_face_with_smiling_eyes: :face_with_stuck-out_tongue_winking_eye:
