  3. Top End
  4. Ported Athena 170 kit with 34mm Carb and Athena System
2 Posts 1 Posters 988 Views
  • T Offline
    T Offline
    theportingmaster
    Hi, Have a ported Athena 170 kit for sale if anyone is interested with a brand new 34mm carb and full Athena 170 exhaust with it. The cylinder has widened exhaust port along with modified transfer ports, comes with an alloy base spacer as cylinder has had 1.3mm machined off the top of it to alter the port timings for more power. The base spacer must be fitted along with a standard base gasket as if the spacer is not fitted the piston will hit the head due to the narrow squish band. The cylinder has done 3,000 miles mainly green laning and plenty of wheelies which it does very easily, the chrome bore is mint and has a brand new pair of piston rings with it that cost £80. Has a brand new 34mm PWK carb with it jetted to suit and spare jets with it, has an Athena 170 steel expansion chamber and Athena 170 silencer. Exhaust has a small dent in it and could do with a coat of paint on it to tidy it up. Very quick as it has the extra 170cc torque as well as revving to 11,000.
    Message me if interested. cheers Terry.
    • T Offline
      T Offline
      theportingmaster
      HI, ALL SOLD NOW..
