  3. Brakes
  4. Front calliper on Rear?...
21 Posts 6 Posters 9.5k Views
    @MadGyver
    It’s be nice to know which bikes to be looking for! The DTR125 is a 12.7mm piston I think. I’ve found an unknown bike Nissin that looks the same but is 14mm for a reasonable price. Thinking of getting it. The prices on eBay are unfuckin believable! When are these jokers gonna realise that a realistic priced item will sell! Instead of cluttering up the web with overpriced, repeat, repeat, repeat, items that never sell 🤨 All copying the same unrealistic price cause they’re sheeple that’ve seen others do it!...
    Pisses me off!...
    Do DTR125 and dtx125 share the same front hubs? I’m wondering about mounting a 30cm disc obviously. Sorry if this has been asked a 100 times before!...
    Be nice to know if the fork bottoms are the same as well 😉 ...
      Ok. There’s over 5mil difference between the two disc centres. Oh well, if you don’t ask yo don’t piss people off for asking the same dumb questions 😜
        Has anyone fitted a DTR125 front calliper onto the rear wheel? I know it’s not a huge difference but it does have a bigger piston and theoretically more force? If not why do they fit them to the front?...
        It’s not difficult, just swap the slide bolt over to the other side of the mount...
        I also just noticed that the front calliper on my TZR is a 4 piston Sumitomo and the rear is a 2 piston. I don’t think they’re viable for a mod though cause of clearance...
        T
        T
        theportingmaster
        @SpookDog Could always fit 2 calipers👍
        https://www.50stunt.com/v/vspfiles/assets/images/yamaha wr250x dual caliper bracket 50stunt.jpg
        https://www.50stunt.com/YAMAHA_WR250X_DUAL_CALIPER_HANDBRAKE_THIRD_BRAKE_p/smhb_wrx.htm
          @MadGyver
          Pisses me off!...
          @SpookDog said in Front calliper on Rear?...:
          @MadGyver
          Pisses me off!...
          That might work. ( ((14/2 squared) x 3.142) - ((12.7/2 squared x 3.142) ) / ((12.7/2 squared x 3.142) ) x 100% = 21.5% more fluid displaced when you move the 14mm m/cyl piston the same distance compared to the 12.7mm piston.
          What are the diameters of the front and rear DTR caliper pistons please?
            @MadGyver
            Pisses me off!...
            Front is 55mm
            Rear is 50mm
            I think!...
              @SpookDog Well anything is possible if you can be bothered. I retrofitted RS 125 Calipers to mine.
              Best thing about this bike is how it stops!
              M
              M
              MH-Bikes-N-Bits
              wrote on last edited by MH-Bikes-N-Bits
              @Calum That aprilla logo would really annoy me would have to machine that on off 😅
              • M MH-Bikes-N-Bits
                @MH-Bikes-N-Bits Yeah, I done this like 10 years ago when I was just a wee nipper. Nowadays I do like to file off markings like that. Pretty sure Aprilia don't make them and they are actually Brembos.
                On the Cagiva they run the same brake calipers as the RS but with Brembo stamps instead of Aprilia/Cagiva.
                • T theportingmaster
                  @theportingmaster
                  That is definitely food for thought! Though I’m having to put my upgrade ideas on hold till I can sort out my head again! Shame, the old thing was going so well, picking up smooth and quick through the band and all. So much so I proper noticed how woeful the brakes are on these bikes! 😳
                    Front is 55mm
                    Rear is 50mm
                    I think!...
                    @SpookDog I had some old front/rear pistons accessible so was able to measure them, stock DTR front is 35mm and rear is 30mm dia. so:
                    ( ((17.5 squared) x 3.142) - ((15 squared) x 3.142) ) / ( ((15 squared) x 3.142) x 100% ) = front caliper has 36.1% more piston area than rear, meaning you need a rear master cylinder which displaces 36% more fluid than the stock 12.7mm bore item to run a front caliper on the rear and retain the rear brake action/feel/pedal travel.
                    So reversing the master cylinder equation gives us:
                    (Square root ( (((6.35 squared) x 3.142) x 1.36) / 3.142) )
                    = New rear m/cyl piston radius
                    = 7.40mm meaning you’ll need a master cylinder with a bore just under 15mm.
                    Check by comparing with the stock setup (12.7mm dia. m/cyl and 30mm dia. caliper pistons):
                    STOCK
                    ((15 squared) x 3.142) / ((6.35 squared) x 3.142) = 5.58 (m/cyl. piston moves 5.58 times the distance of caliper piston because caliper piston has 5.58 times the m/cyl. piston’s area)
                    FRONT CALIPER AND 14.8MM BORE M/CYL
                    ((17.5 squared) x 3.142) / ((7.4 squared) x 3.142) = 5.59 (m/cyl. piston moves 5.59 times the distance of caliper piston because caliper piston has 5.59 times the m/cyl. piston’s area).
                    FRONT CALIPER AND 15MM BORE M/CYL
                    ((17.5 squared) x 3.142) / ((7.5 squared) x 3.142) = 5.44 (m/cyl. piston moves 5.44 times the distance of caliper piston because caliper piston has 5.44 times the m/cyl. piston’s area; a 15mm dia. bore m/cyl will slightly reduce brake feel/pedal travel but probably not noticeable. 15mm bore is probably available somewhere).
                    FRONT CALIPER AND 14MM BORE M/CYL
                    ((17.5 squared) x 3.142) / ((7 squared) x 3.142) = 6.25 so if you run the 14mm bore m/cyl. the rear brake will be noticeably spongy; pedal might hit the frame/footpeg mount before locking the wheel which won’t please the MOT man!
                    I’ve never tried anything like this and the numbers surprised me so if anyone has anything to add don’t hesitate (checked as best I can but it’s late!). However it does seem logical as anything cylindrical has a big increase in displacement for a small increase in diameter. Hence the twin .50 caliber Brownings in a B-17 tail turret could do a lot more damage than the four .303s fitted to the Lancaster, even though all four .303s had a much higher rate of fire and could pour out a lot more rounds.
                      STOCK
                      That’s some impressive math! Sorry I was so far out on the measurements 😳
                        @SpookDog Thanks bud no worries, I've been meaning to take a look at this for a while as front calipers are a lot easier to get hold of than rears. And if you can find a suitable master cylinder you'll get the added benefit of a proper dust seal which the stock rear caliper doesn't have! 👍
                          @HOTSHOT-III so I am running the stock Nissin rear master cylinder and those RS brakes stop on a dime!
                            @Calum Interesting, what diameter is the caliper piston(s) please? And is there a significant difference in pad area compared to a stock DTR rear caliper? Nice bit of machining BTW
                              @HOTSHOT-III it’s a twin piston calliper I think. The ones that bolt together usually are...
                              The front m/cyl on the DTR125 is 14mm yes? I got one coming off of fleabay. Looks just like a standard rear but 14. Don’t know if the holes line up but will see!🤞
                              I’m not sure if I can see the benefit of a bigger piston diameter on the slave, not when the pads are the same surface area on the front and rear?
                              I’m having trouble understanding where the beneficial ‘fulcrum’ is, if that makes any sense?! Where does it maximise PSI over a bigger surface area? That’s what brakes are about no? Plus added ‘leverage’ from a bigger diameter disc?
                              I’m really sorry if I’m not making sense! This is all new thinking to me 🙂 ...
                                Got the new 14mm rear master. It’s amazing how good the build quality is!...
                                Don’t know when I’ll refit the 35mm front on the rear with the new master. Will let peeps know if there are any real benefits...
