  3. Got Big One Exhaust need adapter to go on DEp system
7 Posts 4 Posters 2.5k Views
  • primal carnageP
    primal carnageP
    primal carnage
    wrote on last edited by primal carnage
    Can anyone tell me what adapter i need coz when i try to put new can on its 1ml to fat on the the dep pipe do i grind the end down on the dep or is there an adapter that will fit so i can just slide my new can on coz at the moment its a mll to big to go in
    • primal carnageP primal carnage
      Scootjockey
      @primal-carnage
      Is the big one expansion pipe too big diameter or is the DEP tail pipe too big so that you would need to install a collar ? Or is it the other way round ? I know from experience I bought an “old” DEP full system and the tail pipe was in a poor state so ordered a new tailpipe and when I went to fit it, it was too small to slide onto the connecting pipe of the expansion pipe. As I later found DEP have changed the design an you can’t mix n match the old and new systems. If your looking for an insert collar try this kinda thing on Alibaba. If you know the diameter of the two pipes you may find an external/internal reducer ?
      Spend some time looking on this site as it’s in china and they supply everything for anything
      https://www.alibaba.com/product-detail/High-performance-heat-resistant-Exhaust-pipe_60761771733.html?spm=a2700.galleryofferlist.normal_offer.d_title.5f1129ffi9P55O
      primal carnageP 1 Reply Last reply
      • S Scootjockey
        @primal-carnage
        primal carnageP
        primal carnageP
        primal carnage
        @Scootjockey o orded some clips but they were way to big lol..so i cut i small half cm line down both sides of the can so it fitted over the tail pipe nicely and the i used heat resistant rubber off car hose and then two jubilee clips over that works spot on with heat proof tape on the inside off the plastic
        how do i up load pics of my bike to this group keeps saying picture diementions to big off my pc
          Scootjockey
          @primal-carnage
          The last photos I uploaded I took with my iPhone airdropped them to the iPad then clicked on the last photo image on the top of the message under the header and uploaded them. But can I hell do it again 🙄
          CalumC S 3 Replies Last reply
          • S Scootjockey
            @primal-carnage
            @Scootjockey I don't support image hosting, you need to use a image hosting site and embed them into your posts. Hosting images is expensive so I don't do it.
            • S Scootjockey
              @primal-carnage
              @Scootjockey
              Post the pics on Imgur then copy the link and paste it into the
              ![alt text](image url) Between the 2 ( ) brackets where it says image url
              Second icon/button from the left on the tool bar…
              • S Scootjockey
                @primal-carnage
                @Scootjockey
                The Imgur app can be used just on your iPhone, upload to an Imgur site thread, then copy the link of the individual pic and put it into the ![alt text](COPY LINK HERE) option 2nd from the right in the toolbar above that is visible when posting to a thread…
