  3. Derestricting
  4. Derestrict yamaha dt 125 r 1997
66 Posts 5 Posters 31.1k Views
    @Mr-Shadi
    I’m going to say yes. I’ve never seen one myself but it’s matching every description I’ve heard 🙂
    You just have to move it away from the back of the rev counter/speedo clock and isolate it from them…
    Do you have a rev counter and a speedo? Or just the speedo? I always thought that the reed-switch/bulb was behind the rev counter, but I could be wrong….
    Mr ShadiM
    Mr ShadiM
    Mr Shadi
    @SpookDog i have both. i isolated it with electric tape but it still dosent let me go over 80km/h and now the rev limiter can be heard. when i put in 5 gear it wount rev over 6k and same 6 th gear. and sometimes it dosent let me rev over 6k in all the gears but sometimes it does. i dont know what to do.
    Mr ShadiM 1 Reply Last reply
    • Mr ShadiM Mr Shadi
      Mr ShadiM
      Mr ShadiM
      Mr Shadi
      @Mr-Shadi i read the scrim derestriction guide but i am ether blind or there is no explanation how to move forward.
        #33
        @Mr-Shadi
        Have you moved the bulb as far away as you could from where it was? I thought it was behind the rev counter?
        What country are you in? Is the bike native to your country? I’ve never heard of a dt125rn!
        Try putting it back and seeing if the bike at least ‘settles down’!…
        At least something is happening, even if it’s not what you want! It can (sometimes!) help to diagnose the problems 🙂 …
          @Mr-Shadi
          Mr ShadiM
          Mr ShadiM
          Mr Shadi
          wrote on last edited by Mr Shadi
          #34
          @SpookDog i put it away as far as i can but the wire holding rubber is in the way and its near metal if that does anything. the bike is from germany and its in estonia where i am from. i found out that the rn exists trough www.motomike.eu it has parts for that model. and im gonna mess with it again tomorrow cause its 22.29 for me right now and i will go to sleep. Thank you for the help 🙂
            Mr ShadiM
            Mr ShadiM
            Mr Shadi
            #35
            ee14fef3-2273-4a5f-b007-947d8f37199c-image.png from motomike when you put in these settings 2a475a49-4a41-48ac-8859-689570733eaf-image.png
              #36
              @Mr-Shadi
              Have you reconnected the CDI wiring up properly? The reed switch tells the CDI when the bikes doing 60mph then the CDI restricts the revs…
              Get it all running properly before even trying to de-restrict it…
              Also disconnecting the speedo cable should work, as the bike won’t ‘know’ it’s doing 60…
                @Mr-Shadi
                Mr ShadiM
                Mr ShadiM
                Mr Shadi
                @SpookDog i have looked over the wiring and its good and the cdi wiring is good, but the reed switch wires were broken at one point and i melted the wires together with a soldering iron.
                But im doing a full rebuild in a couple of months then ill know if something is broken and i think i will document it here.
                  Mr ShadiM
                  Mr ShadiM
                  Mr Shadi
                  @Mr-Shadi i moved the reed switch, cut wires and did a lot of things but when the reed is out of its slot the bike won't rev over 6k in 2nd 3rd 4th 5th and 6th gear, but when the reed is in its slot it only doesn't rev when 80km/h. I even pulled the reed out a little bit and it didnt rev over 6k. Very weird
                    @Mr-Shadi
                    That is weird! It’s good that you’re experimenting with it…
                    I think that you might have the one that needs a CDI wire cut and earthed. I’ll try and do some reading and let you know 🙂 …
                      @Mr-Shadi
                      Look for a green/black wire on your CDI unit. Let me know if you find one…
                        Mr ShadiM
                        Mr ShadiM
                        Mr Shadi
                        @SpookDog i dont see one. here are some pics 6c8a5cb4-873d-456c-a360-ec6e7030eb31-image.png 7f33e7d3-cb1f-465d-bd87-3606c30dff18-image.png 76aeb926-e8c3-4684-8174-9f02e07c0ee5-image.png ![19f897dc-660c-4bb7-8758-aba0143aa7bd-image.png](/assets/uploads/files/1682163242666-19f897dc-660c-4bb7-8758-50f10cb4-1e93-4f31-8e89-9ec27a4c0055-image.png aba0143aa7bd-image.png) 376af406-420c-4914-94fd-da74734ab6cd-image.png
                          @Mr-Shadi
                          It might be a different colour on account of the weird RN thing…
                          From what I’ve read people move the reed switch then cut & earth a black/green wire…
                          Mr ShadiM S 2 Replies Last reply
                            @Mr-Shadi
                            Mr ShadiM
                            Mr ShadiM
                            Mr Shadi
                            @SpookDog i think if i take the other bikes wiring diagram with black green and then my wiring diagram and then determine witch wire does what. like compare the wire colors for example its bike has red wire as power mine has orange. just a example not reality.
                              @Mr-Shadi
                              Hang on bud! Your bike is a Dt125RN you said? Did you mean a Dtr125 3rn? This would make more sense! 🙄
                                #45
                                Just counted CDI wires on the 3rn diagram in my Haynes manual and it says 11 wires from the CDI. How many have you got?…
                                I’m just curious cause it doesn’t show the reed switch or any wiring to the speedo on the diagram, guess they wouldn’t show the restriction though! 🙂 …
                                  Mr ShadiM
                                  Mr ShadiM
                                  Mr Shadi
                                  @SpookDog it has 18 wires. 3 cdi connectors with 6 wires each.
                                    @SpookDog i also looked under the speedo and there is a white little box with blue and green red wire coming out of it. i tought it was a light but when i looked it had a little space between 2 metal thingies in it and it was covered with glass. Is that the reed switch?
                                    @Mr-Shadi this is a reed switch. If you look at it, it looks to be a broken fuse. When the speedo hits 61 mph it sends an electro magnetic signal and closes the switch which retards the ignition and closes the powervalve back up. Either move it far away from the clocks so the magnet can't reach it or cut it off and keep the wires apart.
                                    Mr ShadiM 2 Replies Last reply
                                      Mr ShadiM
                                      Mr ShadiM
                                      Mr Shadi
                                      @markus-w if i cut it off the bike wount rev over 6k and if i move it it randomly restricts it to 6k rpm. then i need to come to a stop and it revs over 6k.
                                        Mr ShadiM
                                        Mr ShadiM
                                        Mr Shadi
                                        @markus-w and my reed switch allows me to go only 80km/h thats 49.7097 mph
                                          @Mr-Shadi
                                          We need to find out what wires need to be cut and earthed. On my tzr 4hw there are 2 wires that have been cut, joined and earthed by previous owners. A black with lavender-blue stripe and a grey…
