  3. Derestricting
  4. Derestrict yamaha dt 125 r 1997
66 Posts 5 Posters 31.1k Views
    @Mr-Shadi
    Seen a few 3nc’s on eBay lately for reasonable prices. I got one for about £30 a while back…
    Still not convinced you need one yet. Try and find a copy of scrims write up. I found one the other day, I’ll try and get an address…
    Mr ShadiM
    Mr ShadiM
    Mr Shadi
    @SpookDog i searched a bit and found my bike is actually yamaha dt 125 rn 1997. The rn model is restricted to 80 km/h and there is almost no info about that bike.
    • Mr ShadiM Mr Shadi
      @Mr-Shadi
      That’s not even 60mph! Damn! I did think that you might have one of the’stranger’ ones. I still think that scrims deristricting guide is your best bet…
      Mr ShadiM 1 Reply Last reply
        I'd just get a Zeeltronic and be done with it.
          @Mr-Shadi
          Mr ShadiM
          Mr ShadiM
          Mr Shadi
          @SpookDog i also looked under the speedo and there is a white little box with blue and green red wire coming out of it. i tought it was a light but when i looked it had a little space between 2 metal thingies in it and it was covered with glass. Is that the reed switch?
          Mr ShadiM S markus.wM 3 Replies Last reply
            Mr ShadiM
            Mr ShadiM
            Mr Shadi
              #30
              @Mr-Shadi
              I’m going to say yes. I’ve never seen one myself but it’s matching every description I’ve heard 🙂
              You just have to move it away from the back of the rev counter/speedo clock and isolate it from them…
              Do you have a rev counter and a speedo? Or just the speedo? I always thought that the reed-switch/bulb was behind the rev counter, but I could be wrong….
                @Mr-Shadi
                Mr ShadiM
                Mr ShadiM
                Mr Shadi
                @SpookDog i have both. i isolated it with electric tape but it still dosent let me go over 80km/h and now the rev limiter can be heard. when i put in 5 gear it wount rev over 6k and same 6 th gear. and sometimes it dosent let me rev over 6k in all the gears but sometimes it does. i dont know what to do.
                  Mr ShadiM
                  Mr ShadiM
                  Mr Shadi
                  @Mr-Shadi i read the scrim derestriction guide but i am ether blind or there is no explanation how to move forward.
                    #33
                    @Mr-Shadi
                    Have you moved the bulb as far away as you could from where it was? I thought it was behind the rev counter?
                    What country are you in? Is the bike native to your country? I’ve never heard of a dt125rn!
                    Try putting it back and seeing if the bike at least ‘settles down’!…
                    At least something is happening, even if it’s not what you want! It can (sometimes!) help to diagnose the problems 🙂 …
                      @Mr-Shadi
                      Mr ShadiM
                      Mr ShadiM
                      Mr Shadi
                      wrote on last edited by Mr Shadi
                      #34
                      @SpookDog i put it away as far as i can but the wire holding rubber is in the way and its near metal if that does anything. the bike is from germany and its in estonia where i am from. i found out that the rn exists trough www.motomike.eu it has parts for that model. and im gonna mess with it again tomorrow cause its 22.29 for me right now and i will go to sleep. Thank you for the help 🙂
                        Mr ShadiM
                        Mr ShadiM
                        Mr Shadi
                        #35
                        ee14fef3-2273-4a5f-b007-947d8f37199c-image.png from motomike when you put in these settings 2a475a49-4a41-48ac-8859-689570733eaf-image.png
                          #36
                          @Mr-Shadi
                          Have you reconnected the CDI wiring up properly? The reed switch tells the CDI when the bikes doing 60mph then the CDI restricts the revs…
                          Get it all running properly before even trying to de-restrict it…
                          Also disconnecting the speedo cable should work, as the bike won’t ‘know’ it’s doing 60…
                            @Mr-Shadi
                            Mr ShadiM
                            Mr ShadiM
                            Mr Shadi
                            @SpookDog i have looked over the wiring and its good and the cdi wiring is good, but the reed switch wires were broken at one point and i melted the wires together with a soldering iron.
                            But im doing a full rebuild in a couple of months then ill know if something is broken and i think i will document it here.
                              Mr ShadiM
                              Mr ShadiM
                              Mr Shadi
                              @Mr-Shadi i moved the reed switch, cut wires and did a lot of things but when the reed is out of its slot the bike won't rev over 6k in 2nd 3rd 4th 5th and 6th gear, but when the reed is in its slot it only doesn't rev when 80km/h. I even pulled the reed out a little bit and it didnt rev over 6k. Very weird
                                @Mr-Shadi
                                That is weird! It’s good that you’re experimenting with it…
                                I think that you might have the one that needs a CDI wire cut and earthed. I’ll try and do some reading and let you know 🙂 …
                                  @Mr-Shadi
                                  Look for a green/black wire on your CDI unit. Let me know if you find one…
                                    Mr ShadiM
                                    Mr ShadiM
                                    Mr Shadi
                                    @SpookDog i dont see one. here are some pics 6c8a5cb4-873d-456c-a360-ec6e7030eb31-image.png 7f33e7d3-cb1f-465d-bd87-3606c30dff18-image.png 76aeb926-e8c3-4684-8174-9f02e07c0ee5-image.png ![19f897dc-660c-4bb7-8758-aba0143aa7bd-image.png](/assets/uploads/files/1682163242666-19f897dc-660c-4bb7-8758-50f10cb4-1e93-4f31-8e89-9ec27a4c0055-image.png aba0143aa7bd-image.png) 376af406-420c-4914-94fd-da74734ab6cd-image.png
                                      @Mr-Shadi
                                      It might be a different colour on account of the weird RN thing…
                                      From what I’ve read people move the reed switch then cut & earth a black/green wire…
                                      Mr ShadiM S 2 Replies Last reply
                                        @Mr-Shadi
                                        Mr ShadiM
                                        Mr ShadiM
                                        Mr Shadi
                                        @SpookDog i think if i take the other bikes wiring diagram with black green and then my wiring diagram and then determine witch wire does what. like compare the wire colors for example its bike has red wire as power mine has orange. just a example not reality.
                                          @Mr-Shadi
                                          Hang on bud! Your bike is a Dt125RN you said? Did you mean a Dtr125 3rn? This would make more sense! 🙄
