  3. Derestricting
  4. Derestrict yamaha dt 125 r 1997
66 Posts 5 Posters 31.1k Views
    Yeah that makes more sense 404 - Not Found. I think you'll find 403 is Forbidden @SpookDog
      I’m worried that he might have the one with the ‘silver box behind the 2T oil tank’ that needs loads of faffing about! I tried getting scrims guide up but kept getting a 401 error!…
      Mr ShadiM
      Mr ShadiM
      Mr Shadi
      @SpookDog i don't seem to have a silver box behind the oil tank. The only silverish/grayish box is the voltage regulator.
        On a copy (of scrims) on another site it said to install an earlier CDI I think? Yamaha certainly had it in in for you lads with later bikes! Access Forbidden! 😛 SNAFU! ☠️ …
        My bad! It was 404 not quite as verboten! 😎 …
        Mr ShadiM
        Mr ShadiM
        Mr Shadi
        @SpookDog scrims sites hosting server has stopped broadcasting the info. But there is a slideshare link on the forum that has the site in slide form
        Mr ShadiM 1 Reply Last reply
        • Mr ShadiM Mr Shadi
          Mr ShadiM
          Mr ShadiM
          Mr Shadi
          @Mr-Shadi on the way back machine, its possible to see the old dt 125 net and other sites but not a lot of info on them
            @SpookDog 401? That's Unauthorized
            Right, yeah I don't know about that one. I only really researched the one for my bike.
            Best thing to do is get a Zeeltronic ignition system for it and you're laughing.
            Mr ShadiM
            Mr ShadiM
            Mr Shadi
            @Calum i just bought the bike so i have no money to buy a 300 euro cdi. Trying to do it for free
              @Mr-Shadi Sure, but some models of DTRs were heavily restricted via the CDI, so you're literally gimped until you replace it with either a less restrictive CDI or an aftermarket one.
                Mr ShadiM
                Mr ShadiM
                Mr Shadi
                @Calum ok thank you for the help. will save some money to buy one then
                  #24
                  @Mr-Shadi
                  Seen a few 3nc’s on eBay lately for reasonable prices. I got one for about £30 a while back…
                  Still not convinced you need one yet. Try and find a copy of scrims write up. I found one the other day, I’ll try and get an address…
                    @Mr-Shadi
                    Mr ShadiM
                    Mr ShadiM
                    Mr Shadi
                    @SpookDog i searched a bit and found my bike is actually yamaha dt 125 rn 1997. The rn model is restricted to 80 km/h and there is almost no info about that bike.
                      @Mr-Shadi
                      That’s not even 60mph! Damn! I did think that you might have one of the’stranger’ ones. I still think that scrims deristricting guide is your best bet…
                        I'd just get a Zeeltronic and be done with it.
                          @Mr-Shadi
                          Mr ShadiM
                          Mr ShadiM
                          Mr Shadi
                          @SpookDog i also looked under the speedo and there is a white little box with blue and green red wire coming out of it. i tought it was a light but when i looked it had a little space between 2 metal thingies in it and it was covered with glass. Is that the reed switch?
                          Mr ShadiM S markus.wM 3 Replies Last reply
                            Mr ShadiM
                            Mr ShadiM
                            Mr Shadi
                              #30
                              @Mr-Shadi
                              I’m going to say yes. I’ve never seen one myself but it’s matching every description I’ve heard 🙂
                              You just have to move it away from the back of the rev counter/speedo clock and isolate it from them…
                              Do you have a rev counter and a speedo? Or just the speedo? I always thought that the reed-switch/bulb was behind the rev counter, but I could be wrong….
                                @Mr-Shadi
                                Mr ShadiM
                                Mr ShadiM
                                Mr Shadi
                                @SpookDog i have both. i isolated it with electric tape but it still dosent let me go over 80km/h and now the rev limiter can be heard. when i put in 5 gear it wount rev over 6k and same 6 th gear. and sometimes it dosent let me rev over 6k in all the gears but sometimes it does. i dont know what to do.
                                  Mr ShadiM
                                  Mr ShadiM
                                  Mr Shadi
                                  @Mr-Shadi i read the scrim derestriction guide but i am ether blind or there is no explanation how to move forward.
                                    #33
                                    @Mr-Shadi
                                    Have you moved the bulb as far away as you could from where it was? I thought it was behind the rev counter?
                                    What country are you in? Is the bike native to your country? I’ve never heard of a dt125rn!
                                    Try putting it back and seeing if the bike at least ‘settles down’!…
                                    At least something is happening, even if it’s not what you want! It can (sometimes!) help to diagnose the problems 🙂 …
                                      @Mr-Shadi
                                      Mr ShadiM
                                      Mr ShadiM
                                      Mr Shadi
                                      wrote on last edited by Mr Shadi
                                      #34
                                      @SpookDog i put it away as far as i can but the wire holding rubber is in the way and its near metal if that does anything. the bike is from germany and its in estonia where i am from. i found out that the rn exists trough www.motomike.eu it has parts for that model. and im gonna mess with it again tomorrow cause its 22.29 for me right now and i will go to sleep. Thank you for the help 🙂
                                        Mr ShadiM
                                        Mr ShadiM
                                        Mr Shadi
                                        #35
                                        ee14fef3-2273-4a5f-b007-947d8f37199c-image.png from motomike when you put in these settings 2a475a49-4a41-48ac-8859-689570733eaf-image.png
                                          #36
                                          @Mr-Shadi
                                          Have you reconnected the CDI wiring up properly? The reed switch tells the CDI when the bikes doing 60mph then the CDI restricts the revs…
                                          Get it all running properly before even trying to de-restrict it…
                                          Also disconnecting the speedo cable should work, as the bike won’t ‘know’ it’s doing 60…
