  3. Derestricting
  4. Derestrict yamaha dt 125 r 1997
66 Posts 5 Posters 30.6k Views
  • Mr ShadiM Mr Shadi
    @Mr-Shadi the model is 4BL
    and its originally from Germany
    @forum members
    Isn’t there a later model that needs a CDI wire cutting & earthing somewhere? Or is that a Tzr?…
    I’m sorry Mr-Shadi, I don’t know too much about later than 1995 model dtr125’s, other than what I have read. What country is your bike from? I’m guessing that english isn’t your first language?
    I’ll do a bit of reading and try to find out about 1997 bikes…
    Edit: 4dl Germany! Got it!
      @forum members
        The DTRE has a green and black wire, once earthed that's all the electrical restrictions and then the bike revs off the clocks.
          I’m worried that he might have the one with the ‘silver box behind the 2T oil tank’ that needs loads of faffing about! I tried getting scrims guide up but kept getting a 401 error!…
          CalumC Mr ShadiM 2 Replies Last reply
            @SpookDog 401? That's Unauthorized
            Right, yeah I don't know about that one. I only really researched the one for my bike.
            Best thing to do is get a Zeeltronic ignition system for it and you're laughing.
            S Mr ShadiM 2 Replies Last reply
              On a copy (of scrims) on another site it said to install an earlier CDI I think? Yamaha certainly had it in in for you lads with later bikes! Access Forbidden! 😛 SNAFU! ☠️ …
              My bad! It was 404 not quite as verboten! 😎 …
              Mr ShadiM 1 Reply Last reply
                Yeah that makes more sense 404 - Not Found. I think you'll find 403 is Forbidden @SpookDog
                  Mr ShadiM
                  Mr ShadiM
                  Mr Shadi
                  @SpookDog i don't seem to have a silver box behind the oil tank. The only silverish/grayish box is the voltage regulator.
                    Mr ShadiM
                    Mr ShadiM
                    Mr Shadi
                    @SpookDog scrims sites hosting server has stopped broadcasting the info. But there is a slideshare link on the forum that has the site in slide form
                      Mr ShadiM
                      Mr ShadiM
                      Mr Shadi
                      @Mr-Shadi on the way back machine, its possible to see the old dt 125 net and other sites but not a lot of info on them
                        Mr ShadiM
                        Mr ShadiM
                        Mr Shadi
                        @Calum i just bought the bike so i have no money to buy a 300 euro cdi. Trying to do it for free
                          @Mr-Shadi Sure, but some models of DTRs were heavily restricted via the CDI, so you're literally gimped until you replace it with either a less restrictive CDI or an aftermarket one.
                            Mr ShadiM
                            Mr ShadiM
                            Mr Shadi
                            @Calum ok thank you for the help. will save some money to buy one then
                              #24
                              @Mr-Shadi
                              Seen a few 3nc’s on eBay lately for reasonable prices. I got one for about £30 a while back…
                              Still not convinced you need one yet. Try and find a copy of scrims write up. I found one the other day, I’ll try and get an address…
                                @Mr-Shadi
                                Mr ShadiM
                                Mr ShadiM
                                Mr Shadi
                                @SpookDog i searched a bit and found my bike is actually yamaha dt 125 rn 1997. The rn model is restricted to 80 km/h and there is almost no info about that bike.
                                  @Mr-Shadi
                                  That’s not even 60mph! Damn! I did think that you might have one of the’stranger’ ones. I still think that scrims deristricting guide is your best bet…
                                    I'd just get a Zeeltronic and be done with it.
                                      @Mr-Shadi
                                      Mr ShadiM
                                      Mr ShadiM
                                      Mr Shadi
                                      @SpookDog i also looked under the speedo and there is a white little box with blue and green red wire coming out of it. i tought it was a light but when i looked it had a little space between 2 metal thingies in it and it was covered with glass. Is that the reed switch?
                                      Mr ShadiM S markus.wM 3 Replies Last reply
                                        Mr ShadiM
                                        Mr ShadiM
                                        Mr Shadi
                                          #30
                                          @Mr-Shadi
                                          I’m going to say yes. I’ve never seen one myself but it’s matching every description I’ve heard 🙂
                                          You just have to move it away from the back of the rev counter/speedo clock and isolate it from them…
                                          Do you have a rev counter and a speedo? Or just the speedo? I always thought that the reed-switch/bulb was behind the rev counter, but I could be wrong….
