  4. Runs with choke
Runs with choke
76 Posts 6 Posters 14.6k Views
  • OllieDTRO Offline
    OllieDTRO Offline
    OllieDTR
    Hi guys, just rebuild my engine on a dtr I’ve just bought, did all gearbox bearings, crank bearings, con rod, all seals etc etc, bike sounds lovely.
    But it only idles good on choke, soon as you put the choke down it still idles fine then you give it some revs and it hangs for around 5 seconds then dies down, almost like a lean / air leak, I’ve checked all the boots and they are tight with jubliee clips and it’s got brand new crank seals so wouldn’t think it’s that, on choke though you can rev it and dies down straight away.
    Engine is a electric start one with a TM28ss flat slide carb
    Pilot jet 22.5
    Main jet 210
    Needle clip middle
    Carb doesn’t leak
    Modifications to engine
    1mm oversize piston
    5mm reed valve spacer
    Dep exhaust
    Boyseen dual stage reeds with rev plate (so no metal reed fins)
    Any help would be amazing, thank you!
    • R Offline
      R Offline
      Rallyfinnen
      Best thing to do would be a leak test sealing up the intake and exhaust, and pressurize it slightly. I usually 'cheat' by removing the carb, and putting in a plug with a tire valve in the intake, and feed it with some pressurized air (not to much pressure, or seals will blow out). Make sure piston is at TDC, or at least high enough to close the transfers. There will be some slight leak through the exhaust, but disregarding that, it should let you verify that the intake side and crank case is sealing. Listen for leaks at crank case sealing surface, flywheel side, and through the gearbox oil filling hole. You can also spray some soap water on the external sealing surfaces and watch for bubbles. A compressor with a variable pressure regulator is ideal, just adjust the pressure regulator to a really low value.
      OllieDTRO 1 Reply Last reply
      • R Rallyfinnen
        OllieDTRO Offline
        OllieDTRO Offline
        OllieDTR
        @Rallyfinnen
        Thank you! I will try that.
        I’m also going to take the carb off and give that a good clean and maybe bring pilot jet up.
        I was just wondering does anyone have a Haynes manual or know the correct jetting for my engine it starts with E117E
        It’s an electric start engine that’s in my dtr 1989
        Little bit of research and it’s a 2004+ engine?
        So just looking for the jetting first
        Thank you again
        • OllieDTRO OllieDTR
          @Rallyfinnen
          Thank you again
          @OllieDTR
          22.5 is right for the 210 main and year. Please don’t change the pilot jet, fix the problem 🙂 …
          Did it idle properly before the build? You have an air leak somewhere for sure. I usually spray brake/clutch cleaner around the rubber inlet while the engine is running…
            @OllieDTR
            OllieDTRO Offline
            OllieDTRO Offline
            OllieDTR
            I know it’s correct for the year mate but remember I got Boyseen dual stage reeds, Reed spacer, dep pipe and forgot to mention I got snorkel removed as didn’t come with one with the bike, I’ll check tomorrow with spray in some areas around carb etc to see if it revs higher
            Thanks
              Thanks
              @OllieDTR
              Non of that would affect the mixture tho. Did it run when you got it or is this it’s first time? Just trying to suss out if you’ve inherited a problem…
              Revs should drop and settle when sprayed…
              • OllieDTRO Offline
                OllieDTRO Offline
                OllieDTR
                so I bought the bike non running, mate got brand new top end for it, was running but same problem revs hanging, then when went to sell it wouldn’t start, the video I saw from the bike engine didn’t sound to healthy, so thought I’d take it all apart when I got into it the main bearing race was all broken so that’s why it sounded notchy, lucky I did as that could of ended bad if it seized. So rebuilt the whole engine, it sounds lovely now, the issue for not starting when I got it from him was faulty coil pack. I’ll try the spray tomorrow and report back thanks @SpookDog
                  @OllieDTR
                  You’ve had the carb apart though? Cause you know the jet sizes? When I got my bike it had 1988 26mm jet sizes (180 main 20 pilot) fitted into a late 90s~2000 carb that used totally different 240 main.25 pilot. Just because the previous owner thought it was right, and I never knew better 🙄…
                  I went through every combination of jet years! 😛
                  Thing is it’s not the year of the engine that matter, it’s the year of the carb. I blew head gaskets every 700miles for two years because I had too small a pilot jet, then a proper jet that was partially blocked with hard varnish/deposit. I wouldn’t of believed a pilot could cause such mayhem if I hadn’t lived it myself!!…
                  There are a couple ‘tell-tales’ that help you year your carb, I’ll look in the Haynes when I get home later on and post them…
                    @OllieDTR
                    OllieDTRO Offline
                    OllieDTRO Offline
                    OllieDTR
                    Yeah I’ve had the carb apart float height is standard not messed with
                    It’s a TM28ss Flatslide carb from the newer years not round side
                    I know it’s 22.5 stock pilot and 210 main
                    Going to test for air leaks shortly
                      @OllieDTR
                      What I’m saying is they made 2 or 3 different Mikuni flatslide carbs, each with its own jetting. Mine is 240 main .25 pilot. Put a 210 & .225 in and it doesn’t like it! 😛
                      You might have a later carb that a previous owner put earlier jets into…
                        @OllieDTR
                        OllieDTRO Offline
                        OllieDTRO Offline
                        OllieDTR
                        @SpookDog good shout that mate, maybe why then I’ve ordered jets anyways just incase there is no leaks it will be that then
                          @OllieDTR
                          Not easy getting a Mikuni .25 in the UK. You live abroad?…
                          • OllieDTRO Offline
                            OllieDTRO Offline
                            OllieDTR
                            Update, checked carb with brake cleaner no air leaks, idled better the more the air screw is in so definitely in need of bigger pilot jet.
                            @SpookDog Yes I live in the UK, I’m from Dorset
                              @OllieDTR
                              Whereabouts? I’ve got a slightly enlarged.25 & a 250 main you could try. If you do have the later carb the .25 airscrew is supposed to be 1 & 1/4 turns out. I’d try your setup at 1/2 to 3/4 turns…
                              I bounce between blandford and Poole…
                              PS I got a good copy jet at sportax racing. Couldn’t find a genuine in the UK
                              • OllieDTRO Offline
                                OllieDTRO Offline
                                OllieDTR
                                Update:
                                Took the carb apart again, checked float height 16mm
                                Everything is perfect emulsion tube is missing an o ring, all the kits I see don’t come with one, but on my other dtr carb it has one. Where is best to get a rebuild kit that actually is decent rather than the Chinese cheap stuff? My needle is also bent, what needle code has everyone got?
                                Thank you,
                                After that if nothing has changed then the left hand side seal has gone already I’m taking it even only being just fitted maybe the cheaper seals don’t last at all
                                  Update:
                                  Thank you,
                                  @OllieDTR
                                  None of my carbs have an o-ring fitted to the tube. Just a brass washer under the main jet.
                                  What size is your pilot?…
                                  I’ll get needle size posted later when I get back to my shed 🙂 …
                                  • OllieDTRO Offline
                                    OllieDTRO Offline
                                    OllieDTR
                                    Little update: changed pilot jet from 22.5 all the way to 27.5 and no difference in running without choke, air screw not doing anything, put the needle to the richest possible still nothing, so it’s got to be an air leak only place now is the left hand side crank seal, I’ve replaced them all but they was only eBay ones so could be that, so gone with viton high quality one now.
                                    What is the float height guys for the TM28ss? It’s at 16mm at the moment
                                    Thank you
                                      Thank you
                                      @OllieDTR
                                      If it’s your first time fitting them you may of fuxed up the inner spring or not seated them level. I’ve done it myself, more than once. You don’t have to split the cases to replace them…
                                      I need to reread your thread to see what carb you have fitted. My memory is not wot it used to be 🙂 …
                                        @OllieDTR
                                        2004 onwards:
                                        1DO I.D. mark
                                        210 main
                                        17.5 pilot
                                        5J40 needle 2nd clip from Top
                                        Q2M (938) emulsion tube
                                        2.8 throttle slide cutaway
                                        15.5 ~ 16.5 float height
                                        You may have an earlier carb though. Check the marks your needle & tube have on them…
                                        The earlier one is:
                                        I.D. 3MB00
                                        210 main
                                        22.5 pilot
                                        5J25 needle 4th groove from Top
                                        Q-2 tube
                                        2.5 throttle slide cutaway
                                        Try and suss out what carb you have by the slide cutaway. It’s stamped on it somewhere…
                                        I may have a needle you can borrow to try swapping out. Let me know the markings on yours & slide…
                                        • OllieDTRO Offline
                                          OllieDTRO Offline
                                          OllieDTR
                                          Thanks @SpookDog
                                          My needle is NJ25
                                          I’ve copied all them settings for my carb and still the same runs good with choke but soon as you turn it off it revs high then dies so definitely a lean state.
                                          I’ve ordered a viton crank seal now as I bet it’s that. Being cheap quality this one must of some how broke in the process of install.
                                          As the air screw doesn’t change anything so got to be an airleak there as no where else it could be, as all the other gaskets, are
                                          OEM from fowlers headgasket
                                          And the rest of the gaskets are Vertex so decent
                                          I just ordered a seal kit from eBay for £20 for the lot so that probably explains why the crank seal has gone already lol. These nitrile ones are not strong and no good with fuel I’ve heard.
                                          Other seal is arriving Tuesday/ Wednesday so I’ll update you then.
                                          All the best everyone and thank you
