  3. Derestricting
  4. Need to verify my bike year and model so i can look for restrictions
42 Posts 8 Posters 19.9k Views
    @erionmustafa
    Where do you live?…
    E
    E
    erionmustafa
    @SpookDog kosovo , albania if you heard about it
    • Hark_PtooieH
      Hark_PtooieH
      Hark_Ptooie
      #31
      Just some product info: I got an Athena exhaust resonator for my bike when I derestricted it, kept the stock silencer.
      The Athena gave the bike all the power it was supposed to have and then some - they write something like +3 hp on the site, which would put mine at 26 hp, and I believe it.
      The sound became more peppy - not much louder, but with a harsher metallic zing to it. Could be because I used the old washer, I just got a new one I intend to put there instead.
      However, the fit of the pipe was terrible. The exhaust port screwed on well, the first bracket was 5 mm too far front, the rear bracket a whole 10 mm, so I had to pull like mad and get rid of the screw insert that otherwise should be in the rubber buffer thingy in the bracket.
      Then the rear end that goes into the rubber sleeve was another 10 mm too long on top of that. It basically got pressed into the front end of the silencer with the sleeve as some sort of band-aid around it.
      I managed to get it in place with a bit of violence, and I just got a file and a hacksaw to correct it this weekend.
      I am also not overly impressed with the paint job. It looks okay but seems a bit thin. I'm thinking of putting on an extra layer, but I am not sure what type of paint to use.
        I'll be amazed if it's 26hp. These bikes are seriously not geared up towards those types of numbers. I doubt even my 170 is making that much power. I am looking to get some dyno time very soon so I can say for sure what it makes. But it doesn't hold a candle to my RS or my Cagiva which is probably closer to 26.
        • Hark_PtooieH
          Hark_PtooieH
          Hark_Ptooie
          #33
          I can certainly be off by a good margin, I'm going by seat-of-pants feel here, comparing to 30 year old experiences. But are you speaking of crank hp or drive wheel hp?
          I had a supposedly 22 hp (crank) DT125LC which I actually suspect was more like 19, because specs differ between sources. It was not as peppy as this.
          Then I had a 23 hp DT125R 1990, it was clearly stronger than the first one, hard to tell the difference to this one (I am also 20 kg heavier now).
          Then I had a TT350 - about the same weight and gearing, but 32 hp. It was wheelie friendly.
          While the old DTR gave peak power at 7500 and lost breath at 8500 this one just improves to 9500 where it quits rather abruptly.
          So assuming that it manages roughly the same torque up there as the old DTR, it could be 9000/7500 = 20% stronger, minus error of margin and wear, so I don't think 26 hp is unrealistic.
            The LCs dough!!
            Look at the porting of an LC barrel compared to an R....
            Huge transfer ports on them, cylinder inducted and before the Learner Legal rules.
            LCs absolutely fly 🐷
            • Hark_PtooieH
              Hark_PtooieH
              Hark_Ptooie
              I remember it as somewhat lethargic. The number of times I got stuck in a steep motocross incline because I fell below the power band and stalled, then tumbled down head over heels...
              The unrestricted DTR was/is heads and shoulders better.
                Well, like the R they did various models.
                My brother had a Mk3 LC model one of the very last models and he swears it was leagues ahead of his DTR. He had many an RM250/KX250 YZ 85/125 and a slew of other MX bikes, yet he still to this day goes on about his LC. He was 17 and whilst he'd ridden my mums 900 at 14 and plenty of other big bikes, this would have been his first legal geared bike for the road.
                But I don't doubt him when he ways how much better his LC was than my DTRE lol.
                • R
                  R
                  R3L3_89
                  wrote on last edited by R3L3_89
                  #37
                  Mine is also strange, it's marked as 3ME and DT125E, but otherwise it's identical to DT125R. I did some digging and apparently my bike is Swiss version and it's made in 1989. So far I haven't found any restrictions on the bike (reed switch doesn't even exist) and it easily revs to 10k, however the top speed doesn't go over 85-90 kph with stock gearing of 16/57
                  I haven't torn apart the engine yet so I can't compare it to other models, but it is marked as 3MB-00
                  Then again, I've noticed the expansion chamber is leaking on multiple spots and is generally in a bad condition, someone installed a 4 stroke silencer so the faulty exhaust system could be sapping power
                  • Hark_PtooieH
                    Hark_PtooieH
                    Hark_Ptooie
                    I think the E stands for Europe, not Electric start as some profess. A 1989 model should not have a reed switch and generally do 125-130 km/h. Should have peak power around 7500 and lose its breath at 8500, refuse to go past 9500.
                    At 80 km/h you should be doing 6000 rpm in sixth at stock gearing, right before a momentary torque drop. So in fifth it should get past that and reach 110 km/h. Mine is healthy and accelerates past that torque drop, but if there is something awry with yours it may just be too weak at 7000, but once you get higher it comes back into power?
                    • R R3L3_89
                      #39
                      @R3L3_89
                      Is it revving at 10k when you’re at top speed?…
                      Try counting the number of teeth on you sprockets…
                      Also, do you have a power valve servo fitted?…
                      R 1 Reply Last reply
                        @R3L3_89
                        R
                        R
                        R3L3_89
                        #40
                        @SpookDog no, my revs at top speed are around 8500, i haven't messed with the power valve much but the marks are aligned as it should be and servo is working
                        Sprockets are 16/57
                        • R R3L3_89
                          Sprockets are 16/57
                          @R3L3_89
                          Something is very wrong if you can’t get an unrestricted dtr125 over 55-60mph! Seriously bud. I’m pretty sure mine did that in 4th back when I used to go over 6k rpm!…
                            @R3L3_89
                            R
                            R
                            R3L3_89
                            @SpookDog I'll inspect the power valve from the exhaust port and try to post pictures later, just to be sure
                            The bike feels fast and has good acceleration so there's a possibility that it's just my speedometer that's screwed up LoL
