  4. Dt125r/yz sm
Dt125r/yz sm
36 Posts 6 Posters 27.5k Views 1 Watching
  • C
    C
    chalkey46
    Cheers mate
    DARE TO BE DIFFERENT! !
    • C
      C
      chalkey46
      Now that she is back on the road thought it might be time to get rid of the temporary exhaust so have ordered a stainless steel custom made exhaust should hopefully be here some time this week
      http://i572.photobucket.com/albums/ss167/r1cky_01/FB_IMG_1445814087636_zpsqz0whaox.jpg
      Have also bagged my self a 170 kit with the port timings corrected for a reasonable price with reed spacers and custom alloy inlet which should also be here this week now just need to decide what carb I'm going to run 🙂
      • ConnorDTRC
        ConnorDTRC
        ConnorDTR
        wrote on last edited by ConnorDTR
        Let me know what the pipe sounds like! Really desperate to hear mine! Also did you get that 170 kit of gregiah? If so then he's put alot of work into that kit
        • C
          C
          chalkey46
          Will do mate hoping it's here before Sunday as there is a run what you bung dyno day near me so would like to test it against another good aftermarket exhaust. Yes the kit is of Gregiah seen he was stripping the bike so had a couple of bits off him then he threw me a price on the kit so had to have it
          • C
            C
            chalkey46
            Well my 170 kit turned up todayhttp://i572.photobucket.com/albums/ss167/r1cky_01/20151028_182459_zpswx10jhto.jpg just need to fit it and wait for my exhaust to turn up so I can run it in
            • B
              B
              ballbagsdt125
              nice bike mate! i had a 1992 yz250 offroad are these dt125r bike near enough the same as they look alike by your bike, saving up to get a dt now 🙂
              • C
                C
                chalkey46
                No mate mine has all yz running gear minus the engine thats the only reason they look alike
                • B
                  B
                  ballbagsdt125
                  orite that will explain it lol. thats answerd alot aswell i no theres abit of work to get 1 looking like this,
                  • C
                    C
                    chalkey46
                    Just a bit of work I'm just over 2k in parts so far 👍
                    • B
                      B
                      ballbagsdt125
                      blimy defo worth it tho
                        Yes mate. That inlet is the Tits!
                        Looking good mate.
                        • C
                          C
                          chalkey46
                          http://i572.photobucket.com/albums/ss167/r1cky_01/FB_IMG_1446726262502_zpsnuqzazpj.jpg
                          • C
                            C
                            chalkey46
                            Well thought I may as well beef up the cooling side of the old girl while I was playing so bagged my self a pair of yz twin alloy radshttp://i572.photobucket.com/albums/ss167/r1cky_01/20151111_144943_zpsfrlsrzan.jpg
                              Sick. How are you going to mount them.
                              I run twin rads on my dt. The thing with the YZ ones are the mounting it.
                              Defo worth doing. So long as you don't cool it down too much!
                              • C
                                C
                                chalkey46
                                Going to fabricate new mounts on the frame I think that going to be the easiest way only bought them as the 170 runs slightly hotter than the original
                                  Actually the 170 should run cooler mate. If it's running hotter then it is because the fueling is off. The 170 runs a Nikasil plated barrel which will dissipate the heat better than a steel liner.
                                  Double check the fueling and if that's fine then lower the spark plug grade.
                                  In this weather the engine should run spot on. It really would only be an issue in peak summer.
                                  • C
                                    C
                                    chalkey46
                                    Ah I've not tried the 170 yet as Ive been waiting on other parts was only going on other people's experience with the barrel so I personally have no idea what temp it will run yet I've got an 8,9 and a 10 plug to see what's best and numerous amounts of pilot and main jets and 3 different needles just stocking up haha
                                    • C
                                      C
                                      chalkey46
                                      wrote on last edited by chalkey46
                                      #23
                                      Quick video of first start earlier http://s572.photobucket.com/user/r1cky_01/media/Mobile Uploads/20151116_100648_zps9qsflm9n.mp4.html
                                      But first run on the road didn't go as planned low revs up to 1/2 throttle it's brilliant but after that it's a spluttery mess so now it's time to get the jetting / needle ect set right
                                      • C
                                        C
                                        chalkey46
                                        Had a nice ride out yesterday evening to try and sort out some bugs and got the bike plastered at the same time http://i572.photobucket.com/albums/ss167/r1cky_01/20151118_162852_zps2llmgs8f.jpg
                                        http://i572.photobucket.com/albums/ss167/r1cky_01/FB_IMG_1447962090072_zpsmtnaopto.jpg
                                        But I can confirm I can't wait for it to be fully ran in as it's brilliant as it is now
                                          That looks Amazing. That exhaust looks the tits!
