  4. Dt125r/yz sm
Dt125r/yz sm
36 Posts 6 Posters 27.5k Views 1 Watching
    That looks the tits mate!
    Very very nicely done sir!
    • C
      C
      chalkey46
      Cheers just glad it's finally coming together
      DARE TO BE DIFFERENT! !
      • C
        C
        chalkey46
        With a fresh mot on her she is back on the road still a few more little bits I'm waiting on including a new exhaust but can now ride her againhttp://i572.photobucket.com/albums/ss167/r1cky_01/Mobile%20Uploads/IMG_20151003_175734_zpsvkf2orki.jpg
          Yes mate! Well done.
          • C
            C
            chalkey46
            Cheers mate
            • C
              C
              chalkey46
              Now that she is back on the road thought it might be time to get rid of the temporary exhaust so have ordered a stainless steel custom made exhaust should hopefully be here some time this week
              http://i572.photobucket.com/albums/ss167/r1cky_01/FB_IMG_1445814087636_zpsqz0whaox.jpg
              Have also bagged my self a 170 kit with the port timings corrected for a reasonable price with reed spacers and custom alloy inlet which should also be here this week now just need to decide what carb I'm going to run 🙂
              • ConnorDTRC
                ConnorDTRC
                ConnorDTR
                wrote on last edited by ConnorDTR
                Let me know what the pipe sounds like! Really desperate to hear mine! Also did you get that 170 kit of gregiah? If so then he's put alot of work into that kit
                • C
                  C
                  chalkey46
                  Will do mate hoping it's here before Sunday as there is a run what you bung dyno day near me so would like to test it against another good aftermarket exhaust. Yes the kit is of Gregiah seen he was stripping the bike so had a couple of bits off him then he threw me a price on the kit so had to have it
                  • C
                    C
                    chalkey46
                    Well my 170 kit turned up todayhttp://i572.photobucket.com/albums/ss167/r1cky_01/20151028_182459_zpswx10jhto.jpg just need to fit it and wait for my exhaust to turn up so I can run it in
                    • B
                      B
                      ballbagsdt125
                      nice bike mate! i had a 1992 yz250 offroad are these dt125r bike near enough the same as they look alike by your bike, saving up to get a dt now 🙂
                      • C
                        C
                        chalkey46
                        No mate mine has all yz running gear minus the engine thats the only reason they look alike
                        • B
                          B
                          ballbagsdt125
                          orite that will explain it lol. thats answerd alot aswell i no theres abit of work to get 1 looking like this,
                          • C
                            C
                            chalkey46
                            Just a bit of work I'm just over 2k in parts so far 👍
                            • B
                              B
                              ballbagsdt125
                              blimy defo worth it tho
                                Yes mate. That inlet is the Tits!
                                Looking good mate.
                                • C
                                  C
                                  chalkey46
                                  http://i572.photobucket.com/albums/ss167/r1cky_01/FB_IMG_1446726262502_zpsnuqzazpj.jpg
                                  • C
                                    C
                                    chalkey46
                                    Well thought I may as well beef up the cooling side of the old girl while I was playing so bagged my self a pair of yz twin alloy radshttp://i572.photobucket.com/albums/ss167/r1cky_01/20151111_144943_zpsfrlsrzan.jpg
                                      Sick. How are you going to mount them.
                                      I run twin rads on my dt. The thing with the YZ ones are the mounting it.
                                      Defo worth doing. So long as you don't cool it down too much!
                                      • C
                                        C
                                        chalkey46
                                        Going to fabricate new mounts on the frame I think that going to be the easiest way only bought them as the 170 runs slightly hotter than the original
                                          Actually the 170 should run cooler mate. If it's running hotter then it is because the fueling is off. The 170 runs a Nikasil plated barrel which will dissipate the heat better than a steel liner.
                                          Double check the fueling and if that's fine then lower the spark plug grade.
                                          In this weather the engine should run spot on. It really would only be an issue in peak summer.
