  3. Derestricting
  4. Missing reed switch
Missing reed switch
8 Posts 4 Posters 2.5k Views
  • B
    B
    Blasterguy
    Hey all! My first post here. I have a 2002 DT 125 R with a full power front pipe, but she currently won’t go past 60. I’ve looked over the various forums and pages and I know there should be a reed switch, however rather than removing it from the speedo, some special case has cut it off and wrapped the wires up separately.
    Any ideas of the issues this may/ are causing? I’d expect more than 60mph to be honest. I do also need to check the powervalve, but want to know the implications of the missing switch. All I see everywhere is DO NOT REMOVE IT UNDER ANY CIRCUMSTANCES… but not what removing it actually does ha ha
    Cheers Will
    S 2 Replies Last reply
    • B Blasterguy
      Cheers Will
      @Blasterguy
      I always wondered what simply disconnecting the speedo cable would do.
        It's probably a NC circuit which would be why they say don't remove it.
        Just get yourself a Zeeltronic ignition system and be done with it.
        • B Blasterguy
          Cheers Will
          @Blasterguy
          I think you’re going to have to get another read switch and put it back to standard, then take it from there.
          The last person with similar problems was:
          @Mr-Shadi
          Had problems with his switch. Do a search for his post on the subject…
          • Hark_PtooieH
            Hark_PtooieH
            Hark_Ptooie
            Just pull it out of the bottom of the speedometer housing and wrap it generously in electric tape. Worked on my 2003 DE03.
            As I understand, it is a simple magnetic thing detecting the speed needle passing over it. Removed from its position, it detects nothing. I assume that if you cut it, it detects continuously instead.
            • B
              B
              Blasterguy
              Thanks all- any ideas where I could get a new switch?
              • Hark_PtooieH
                Hark_PtooieH
                Hark_Ptooie
                I am not an electronics guy, but if I found myself without one I would begin by short-circuiting its cables.
                From the looks of it, it's a proximity sensor with two metal blades. In a magnetic field, one is either drawn to or from the other, closing or opening the circuit.
                If the ignition cuts in its absence, I would assume that it is supposed to be Normally Closed and that the lack of it leaves the circuit open - which is interpreted by the ignition as the speedometer needle is close to the sensor. Hence, short-circuiting it would keep it closed at all times.
                But then again - if it would continuously signal "needle at 80 km/h, cut ignition!" regardless of rpm then the engine would not run at all, would it?
                And that was the entirety of my knowledge and understanding of the issue.
                • Hark_PtooieH Hark_Ptooie
                  @Hark_Ptooie
                  It’s a bit of a headfux isn’t it? The read switch might not be a simple magnetic on/off by the looks of it. It might set to a default mode if it the CDI doesn’t detect a continuity in the curcuit?
                  @Blasterguy
                  It would be helpful to know if it only restricts the revs in top gear, or every gear? I would try joining the wires at least once to see if there’s a change at all…
                  It might be easier to get an earlier CDI than a read switch…
