    @SpookDog @HOTSHOT-III Posted some really helpful pictures, but unfortunately they squashed as I had to restore the database...Sorry bud, was a really useful post though.
    @Calum Thanks bud, I wondered what happened to that post, just seen you've been fixing the forum all day 👍
    @SpookDog Here are some cable routing schematics from the Yamaha repair manual, the wiring behind the headlight is a bit of a rat's nest like most trail bikes but this should help you out. Also considering the time of year and the weather we've been having, it's well worth giving the wiring behind the headlight (and under the tank) a thorough blast with WD40 . Throw old towels or dust sheets over both wheels to protect the tyres and brakes, then apply in the manner displayed by the gentleman in the final image. You can also fill up the handlebar switches until it flows out of every orifice, it's a harsh environment for a switch but by doing this regularly you can make the switches last the life of the bike
    S 2 Replies Last reply
      #730
      We walk the Earth, like Jolly Green Giants! But with Guns!!…
      Stay Frosty!…
      Did a test ride: Lights are good! Even the engine is crisper since the PV seems to be kicking in properly!…
      I could of done with routing pics years ago, but they be always welcome 😜 …
      Cheers!…
        Is that manual available online? Or do you own the book? I didn’t know that there was an official workshop manual for the Dtr…
        PS you still got the wheels for sale?…
          @SpookDog Here you go bud, it was the official dealer manual in 1988:
          https://www.ebay.co.uk/itm/323952533497?hash=item4b6d135ff9:g:8mgAAOSw8A1dqtdu&amdata=enc%3AAQAIAAAA0J7povBA%2Fed02ZQWQaloCPHXV9GkRuofT9DZVVp%2BbiuZl6AVamwQCANMTldfO39qzx9CoE1xjcXGtzWtYOLa48iErMAfaeeFL%2B8Ee%2BmjpaRTflmyAenChVIiUQalQM3peHJ2%2Bv1gblqHb%2F86QS6hsY4RvN8OIFKkTrYtH4X1AK2gK%2BAfPKQYAOYtJVuIBwQ0aqOJhDSZog4qRkLPYOfBvRwRikbIP%2FQ4ylJERGtrmNAHoUC%2FpW140AmrFjE1ENEJKq3gt8g0ZpS%2FyzMcYNrfA2A%3D|tkp%3ABk9SR8Lrpaz4Yg
          Obviously you have to be a bit careful because all the engine specs are for the 3DB round slide carb model but the cycle parts are essentially the same on all DTRs right up to 2003. Lots for sale online though, I was able to find an '89 3MB DTRe version with a full colour wiring diagram for about £20 I think.
          And some of the torque settings are frankly ludicrous; for example 20Nm for the disc bolts is off the scale for M6. I destruction tested an old rear one using a spanner in the vice and the 4mm allen head rounded at 16Nm so I did mine on the bike to 12 rear and 14 front and they never moved. However it does show it's wise to invest in genuine bolts or their equivalent for anything structural as a stainless Xmas tree decoration bolt would probably fail at around half that.
          Wheels sold a couple of weeks ago I'm afraid, maybe talk to Salisbury Wheel Builders in Ringwood?
            #733
            I’m glad you sold the wheels, I was only gonna offer £300 😜. …
            If you see an official dealer manual for sale, please drop me a link! I always look for one when I get a vehicle I’m gonna cherish.
            (the 1970’s FG500 one I got looked like an encyclopaedia Britannia!)
            Only seen ‘service’ manuals for the DTr though. I’d love to know if there’s one for the 95> Tzr’s as well!…
              Doh! Only just checked the link! ☺️
              • OllieDTRO OllieDTR
                Hi bud
                Send me your address in messages and I’ll send it out! Sorry I completely forgot to busy ripping on my dt😂
                #735
                @OllieDTR
                Cheers bud! Got the pin today, along with the main bearings I’ve been waiting on forever 🙂 …
                WTF happened to the motor that pic of a piston came out of?! That’s one of the most catastrophic seizures I’ve ever seen! Was it 2T oil or heat? I’m guessing it’s oil related! 😜 Tho it got pretty damn hot by the looks…
                I found a pair of casings I’d forgot about that are less knocked up than the early number ones I was planning on using. It means I can go ahead earlier with my build. Just got to get oil seals and a blaster little end bearing, along with a 170 head gasket from PJME when I get some monies on Wednesday!
                Maybe some new tyres for the salty season.
                Any recommendations for ‘adventure’ tyres? I don’t want road tires but I haven’t been off road in so long I can’t remember. Even then it was dry so the knobblies are kinda like me, redundant 😐 …
                HOTSHOT IIIH OllieDTRO 2 Replies Last reply
                  @OllieDTR
                  @SpookDog Avon TrailRiders in the recommended sizes work very well on the DTR, they're kind of 90% road, 10% dirt; very grippy on tarmac when you run standard pressures 18psi front/22psi rear but just blocky enough to be acceptable off road:
                  https://www.avontyres.com/en-gb/tyres/trailrider?searchtype=car&cartype=motorcycle&car=Yamaha+DT+125+R+1991+-+1997&engine_spec=125
                    #737
                    They have any kinda decent lifespan? I’ve been burnt before with tyres that only lasted 12weeks! Less than 7K miles!…
                    I seem to remember Bridgestone tyre’s having multi density rubber , harder wearing on the centre, mid on the mid and soft on the edges. Helped them maintain their profile throughout the lifespan of the tyre, as well as grip through cornering. Can’t remember which marque they were tho’…
                      @OllieDTR
                      OllieDTRO
                      OllieDTRO
                      OllieDTR
                      Mate was flat out with no coolant 😂
                        #739
                        @SpookDog I think they were Bridgestone Battlaxes which were fitted to the original Honda FireBlade when it came out in '92 (best looking of all the FireBlades IMO; the two round headlights made it look like the GSX-R of the day pumped up on steroids), IIRC they called it SACT (Straight and Cornering Technology). I don't know of any DTR-sized tyre which has dual compound.
                        TrailRiders are no touring tyre but they last pretty well and are a vast improvement over most so-called "dual purpose" tyres which tend to be a bit crap on both dirt and tarmac as it's too much of a compromise. Tyres are a huge part of your setup equation so it's worth accepting a little extra wear if it transforms the bike. I was able to get a deal from an online tyre company by ordering a front and two rears as the rear wears a lot quicker on bikes. This is sensible anyway as bikes are sensitive to mismatched tyres (particularly road-biased tyres) so if you can't get the correct rear when it wears out, you've effectively wasted around half the life of the front tyre.
                        • S
                          Cheers bud, that’s worth thinking about. I don’t mind paying up for quality, just not bling!…
                          Twin round lights have got to be the best looking fairing setup of all time. No amount of ‘fox’ or ‘hawk’ eyes is gonna change that. I’ve always preferred it on cars as well. Mk3 cortina’s or any old capri 😛 …
                            What size for the rear?
                            The front I’m guessing 90/90?
                              #742
                              @SpookDog Avon recommend 80/90 21" front and 110/80 18" rear on the DTR; pretty close to the OEM sizes of 2.75" front and 4.10" rear. If you take a look at the Avon DT125R webpage the recommended rim sizes for these are 1.85" front and 2.50" rear; bigger than the stock DTR rims (1.60" front and 1.85" rear). I had a chat with Avon over the phone about this before getting my 1st set and they told me Yamaha confuse tyre manufacturers with oddball rim sizes quite a lot. I had TrailRiders in these sizes on 2 of my 3 DTRs at one time and it never caused an issue.
                              Definitely the Ford Capri 👍
                              • S
                                Has anyone ever had vapour blasting done before? I got quoted £2 a minute. Works out at £50-80 to get the whole engine, barrel, head, clutch casing, ect done.
                                Good or bad price?…
                                OllieDTRO 1 Reply Last reply
                                  Sounds pricey. I've not paid that much.
                                  I use MB Vapor Blasting and he's VERY competitive.
                                  https://mbengineering.uk/
                                  I've yet to be disappointed.
                                  I cannot recommend Matt more than enough.
                                    Can you remember what you paid for, say, the 2 engine casings and barrel & head? Just to get an idea…
                                    CalumC S 2 Replies Last reply
                                      Good or bad price?…
                                      OllieDTRO
                                      OllieDTRO
                                      OllieDTR
                                      #746
                                      Yes but my brother does all my cnc work, skimming heads, making custom parts etc also done me vapour blading on all my forks and casing etc here is some photos
                                      Is so worth it and will smarten up your build! This is for my French import I’m slowly doing
                                        @SpookDog £30 per hour blasting, is what the invoice says.
                                          FML! 🫤
                                          I wish it would stop being so very wet all the time! I work under a corrugated car port roof on the (cardboard covered) floor at my siss’s house. It really puts a ding into everything I want to do. I need to spray my frame so it doesn’t get ‘salt seasoned’ again this winter, it’s had a rough ‘couple of’…
                                          Can’t do it, so why bother trying to make the motor look good? I’d settle for being able to do a deep clean & degrease on it at the moment…
                                          Sorry, I’m just pissed off @ tm
