  3. 1998 TDR 125 4FU Engine Cutting Out When Warm
7 Posts 3 Posters 2.1k Views
  • L Offline
    L Offline
    Lukeymash
    Hi,
    Hope you are all well.
    I have been having some issues with my TDR. The engine keep cutting out when it warms up.
    This problem originally only happened in 6th gear on the power-band.
    However its since got worse. I wondered if anyone has any advice, I'm hoping its not the stator.
    What I have done so far.
    Cleaned Carb & Both Jets
    New Spark Plug
    New NGK Cap
    New HT Lead
    New Coil
    New Voltage Regulator
    Checked Fuel Flow
    Checked Air Flow
    No overflow Pipes are Blocked
    • L Lukeymash
      Hi,
      New Spark Plug
      New NGK Cap
      New HT Lead
      New Coil
      Checked Fuel Flow
      Checked Air Flow
      @Lukeymash
      Is the radiator full?…
      • MadGyverM Offline
        MadGyverM Offline
        @Lukeymash Welcome to the "club" I have a similar problem and cannot find the resolution.
        I have 2 threads (project thread and electrical section) for that,you may find any info or suggestion that you haven't thought.
        L 1 Reply Last reply
        • MadGyverM MadGyver
          L Offline
          L Offline
          Lukeymash
          @MadGyver I'm Glad to be in the club. I'll keep you updated!
          • L Offline
            L Offline
            Lukeymash
            I'm going to give it one more look at on the weekend. Then I'm going to try a new stator
            • L Lukeymash
              @Lukeymash
              Does it happen at any rev in particular? Throttle full open might be power jet? Does it start up straight again?
              If it doesn’t have you checked the spark at the time?…
              Sorry, more info is King! 🙂 …
                @Lukeymash
                L Offline
                L Offline
                Lukeymash
                @SpookDog I believe I have fixed it now. Swapped out the voltage regulator got it up to temps and it ran fine.
