    @OllieDTR said in So Close!...:
    I have the newer oil pump setup so can adjust it more be good to see if anyone has a guide on how much it needs adjusting by
    I’m going to be running the standard pump to match the standard 28mm carb…
    I think you need to work out the cm2 of the 28mm carb. Then the cm2 of 32mm. Figure out the % increase of the two. Then increase oil at WOT by the same %…
    Or does that sound like BS?…
    #915
    No leaks! Guess what’s next!…
    Time of Rebuild: 44501 miles…
    To be kickstarted soon…
      Oohh exciting 😛
        Oohh exciting 😛
        Yeah I know, I live a very sedentary life. I get bored easily 😉 …
          Went for a test ride, it was OK but getting misfires/knocking at certain lower revs. That and it was taking a bit of effort to tick over cold…
          First thought was check the plug. It looks sweet. Looked to the right at the carb thinking it might be an air leak and remembered I’d changed the rubber inlet manifold. I forgot to blank off the 2T oil pipe inlet! What a twat?!….
          Gonna test it tomorrow with the oil pipe blanked off!…
            Oh, that's a shame. Hopefully all sorted now.
            Took me a little while to get the jetting right on my 170 kit, but now it's done it's lovely.
              Only been to the shop and back so I never properly warmed up. It felt really juddery at low revs, which I put down to the chain being as slack as a wizards sleeve (since corrected!). I’ve yet to take it for a proper test cause I’m all flued up and feel like shit!…
              One thing I’ve meant to ask is about the exhaust tone/note. Not at the tailpipe but deep in the expansion chamber. It sounds really different from before. Anyone gone from standard 3mb to Athena and noticed a similar thing, or not? Any info appreciated 👍 …
              MadGyverM 1 Reply Last reply
                MadGyverM
                MadGyverM
                I have a DEP modified to match the tuning,they tell me that it sounds like a factory 50cc moped not a tuned 170cc, that's until the power band then it screams like a TZ125. When was bought bone stock and abused sounded more serious I could say.
                • MadGyverM MadGyver
                  #922
                  @MadGyver
                  Ive ridden it for 31 miles and it still feels very lumpy with compression when I kick it over. Nothing like when I put a freshly rebored 3mb and piston on it. I could turn it over with my hand then (after riding!).
                  I might be over worrying but I’m wondering if I could do with a thicker base gasket. The standard one is at least 1mm thick I believe?…
                    Is the powervalve all setup working correctly. I haven't got a video of my 170, but it's properly sweet.
                    Shouldn't be juddering, how slack was the chain!
                      Hey bud! Haven’t taken it over 5K so PV isn’t an issue. Chain was very slack, it must’ve bedded in during the 30mile shakedown ride a lot more than I thought possible! I’ve adjusted it up so it has just over 25mm play. I’m waiting till tomorrow to ride it cause I’ve had a few beers…
                      I’m probably worrying too much. I almost expect something to go wrong…
                        #925
                        Chain adjustment has gotten rid of the shuddering, just done 3 miles after warming up and it is riding sweet. Only niggle is at certain low revs when I’m just maintaining speed it sounds almost like there are a few tiny ball bearings in the expansion chamber. I’m guessing it’s a bit of a mixture adjustment in the pilot jet/valve cutaway range. Going to try and richen the airscrew and see what happens…
                        Tick over is very stable so I don’t think it’s a small air leak…
                        All in all it’s good. Pulls like a fuxin freight train @ low revs. Totally different animal! 🙂 …
                          #926
                          Not the prettiest!…
                          I’m thinking of getting some bits of Urban Camouflage (grey, white & black) vinyl made up. Also a different colour seat!…
                          • MadGyverM
                            MadGyverM
                            #927
                            @SpookDog Weren't you plastics Yamaha's endurance blue?
                              #928
                              @MadGyver
                              They were painted bud. The bike was first registered black with red frame and stickers. Most of the panels were dark/navy blue. So it had a hard life before I got it, 16 registered keepers! (I’d love to know how many times it was stolen!)…
                              It’s an old mongrel, not a righteous, numbers matching survivor. Though I am trying to turn it into an honest, righteous bike…
                                #WorkHorse
                                My DT cut out on me on my way home from the work the other day....just ran out of fuel. Switched that bad boy over to reserve and after a few kicks she fired up into life and got me home. NEVER let me down in 13 years of ownership ❤
                                  @MadGyver
                                  MadGyverM
                                  MadGyverM
                                  @MadGyver
                                  I think our DT fates are close,mine was at a coastal rental shop and I leave on a semi touristic island.Was in Germany for 2 years before coming to Greece 11 years as rental.
                                  A properly raped stock unserviced bike when bought,56K km's on factory piston,fux even oil's/fluids where stock.
                                    @MadGyver
                                    I’m still getting some popping/miss at about 1/8 ~ 1/4 throttle. I’ve tried turning the airscrew down from 1 & 1/4 to 1 turn out but it’s not changed anything…
                                    Do Athena officially say anything about jetting? With the standard Mikuni 28…
                                    • MadGyverM
                                      MadGyverM
                                      No,I had searched for troubleshooting my issue,they don't say anything about jetting for the factory carb. Although they recommend premix it's on standard jetting.
                                        #933
                                        Realised I’ve been having problems with electrical, plug and cap, as well as a bit of an air leak with the rubber manifold I used. It’s hard as fux so I’m changing it out for the old , flexible one…
                                        One thing at a time would be nice, but where’s the fun in that, I spose…
                                        Edit: I’ve addressed both problems, just got to wait till tommorry and see if it’s hit the mark, or not 😐🤞 …
                                          #934
                                          Better but no cigar. Got a 27.5 pilot on the way…
                                          I used to have to clean out the pilot a lot before. It was ok but not perfect. I’m using revs between 3~4K I never used before. This is where I’m getting a bit of ‘chatter’…
