1.1k Posts 26 Posters 648.6k Views
    I have 2 ‘spare’ wires near the CDI. One looks pale blue & orange (in equal parts) and the other light green. Could these be solenoid activator wires?…
    There are at least two spare connectors behind the headlight…
    Cheers for doing this. It really does help to know exactly what you’re working with 👍 …
    Now I’ve got a decision to make. What extra gasket to apply to the base of the barrel. I’ve got a standard thickness of 1mm and a 0.5mm.
    Do I go to 1.5 or 2? I’m leaning towards 2mm to be safe, rather a little too much than not enough. I can at least knock it off the list then…
    MadGyverM 1 Reply Last reply
      I put one up against a 3bn/mb valve and of course they’re wider!!
      I did a quick search and it seems like phosphor bronze bushes are all over and cheap as chips! Even the flanged one on the servo side are common.
      I just need to see if I can remove the bronze ring from the brake side without destroying it! It seems that a 4FU one will fit but without the o-ring groove…
      PJME sells the valve for about £50 and the brake side cap for less…
      Can’t get the servo side one new it seems…
      @SpookDog The servo side bushing on the Athena 170/125 kit is a Yamaha part, part number 31K-1131U-00. Athena advise you to buy a new one to fit the kit if you're running it on an original TZR125 as the PV and bushing for that bike (part number starting with 2RL) is smaller in OD (I think). Check it out, it's the OEM servo side powervalve bush on almost every DTR and some DT125LCs:
      https://www.cmsnl.com/products/holder-3_31k1131u00/
      So if you've got a 3MB cylinder with the servo side powervalve bush in good condition, you can just use that or replace the phosphur bronze bush off eBay etc. if it's worn.
        I couldn’t find a single new bush! Cheers bud! Is there a fleabay listing that sell them specifically? I need to get a proper vernier calliper to measure things. I can’t find a half decent one of those. Just Chinese things! I don’t seem to be having any luck searching from my iPhone…
          @SpookDog Those Chinese digital verniers are ace, I bought one for £5 in 2011 and I'm still using it. Exactly the same thing is around £40 in Machine Mart but Aldi/Lidl sell them cheap every now and then.
          Bushes I'm not sure, I've never known a PV bush to be worn enough to replace but I guess you could take the parts to a bearing shop and get them to measure up and order you some.
          Is there any way you could get access to a PC? Smartphones are excellent for what they are but it's difficult looking around for the best deal on a screen the size of a fag packet. Even if you just go online down the Library you can have 3 or 4 windows open on a big screen, makes comparing suppliers etc. a lot easier.
            #951
            I’ve got an old servo side bush that is light years better. The old one you could literally rattle the power valve!! I’ve got a 4fu (male bush) for the other side that is better as well. That side wasn’t as worn though. I’m going to try them, as well as doubling up the base gasket…
            Wish me luck! I’m hopeful cause I sure as shit can’t think what else could be giving me the same symptoms…
            PS! I finally got the Blaster 200 small end bearing fitted! I went the other way and took a bit off of each side of the bearing. Easier to do and cheaper if I’d fuxed it up! Easier to de-swarf as well 😜 …
              MadGyverM
              MadGyverM
              Why you want to do that?
              If you go with 1mm at the base you can use an 0.5mm on the head,will give you 1.1 squish if I remember correctly.
              I made 1.1mm (2x0.55mm) at the base and with 0.55mm at the head the piston came flat with the cylinder and gave me an 1.2mm squish,all copper and handmade.
              • OllieDTRO
                OllieDTRO
                OllieDTR
                My squish is 0.8mm tight but it’s fast lol
                • OllieDTRO OllieDTR
                  MadGyverM
                  MadGyverM
                  @OllieDTR said in So Close!...:
                  You are on 125cc which is ok,for 170cc such a squish is on the red zone for piston hitting.
                  Graham Bell has a pic for the given cc how much must be the squish.
                  • MadGyverM MadGyver
                    @MadGyver
                    Like I said, I had to lap the mouth of the crankcase level. I did it after fitting the head gasket so I couldn’t check the level of the piston crown to the top of the barrel.
                    I’m trying to get it running properly. I’m not in a position to even be thinking about tuning the squish band…
                    Just putting it together again. Power valve feels proper again, not rattling around! Remembered to fit the banjo unions as well 😉
                    It spends far too much time like this. Hopefully it’s fixed now…
                      @MadGyver
                      #956
                      FFS! I can’t believe it but the base gasket is leaking from the same spot as before!
                      I think there must be a slight V at the top of where they join. I put an extra dot of sealant there last time (that it didn’t leak!)
                      I’m going to use silicon RTV the next time. I should of used it to seal the crankcase halves, but I used tube type ‘hermatite’ and I think I ‘washed it out’ while lapping…
                      I’m going to test ride it tomorrow after plugging the leak temporarily. See if at least I fixed the running problem at 1/8 throttle…
                      Can’t seem to catch any breaks! Always fuxin something with me! 🤕
                      • MadGyverM
                        MadGyverM
                        @SpookDog You sanded the whole base or only the mismatch point?
                          @MadGyver
                          I lapped the high side down to match the low. Then the whole thing flush. Using plate glass, wet & dry & wd40. It was only a hairs width…
                          You can see the problem, where the two cases join? The gasket is only 5mm wide at that point. There’s a definite gap where I’ve ‘washed out’ the sealant between the two cases. I just need to be super careful with that spot…
                          • OllieDTRO
                            OllieDTRO
                            OllieDTR
                            For the sake of splitting engine I’d just split it and redo the cases with Threebond 1215, then won’t have any future problems, only takes an hour max to split cases
                              @MadGyver
                              I’ve been assuming that standard base gaskets are 1mm thick, but from what little I can find out it seems Athena gaskets are 0.5mm?
                              Can anyone tell me what the standard Yamaha gasket thickness is? Or what Athena definitely are? Be a big help! 👍 …
                              • MadGyverM
                                MadGyverM
                                #961
                                Yamaha base gaskets also are 0.5mm.
                                I recommend Permatex Form-A-Gasket for your cases.
                                  #962
                                  @MadGyver
                                  Cheers buddy! I’ve been labouring under a misconception!
                                  I’m planning on using copper RTV silicon with a new gasket. 700deg stuff. I’ve had good results with it before. There’s quite an open groove at the front where the two cases join…
                                  I’ll be using it when I next put two cases together as well! 👍 …
                                  • MadGyverM
                                    MadGyverM
                                    @SpookDog If you speak for the base gasket then I advise you to go for a copper one with the Permatex Copper Spray gasket I had mentioned you in some older post here.
                                    Yamaha's base gasket is metallic with black coating and with some melting stuff that forms a line around to seal better.
                                      #964
                                      @MadGyver
                                      You mean the cylinder head gasket? The only base gaskets I’ve seen are paper…
                                      • MadGyverM
                                        MadGyverM
                                        #965
                                        @SpookDog The cylinder base gasket I mean. I know that paper gasket is what they sell. Yamaha's factory one's are metallic,last time I bought. So I used a metallic.
                                          @MadGyver
                                          #966
                                          Initial test ride is promising. Cruising at 25-30 without the previous issues. No tap-rattle and humming from the top end! Won’t know for sure till I take it on a 20-30 mile run though…
                                          Put a spot of chemical metal over the leak for temporary/now…
