  4. Front Light Not Working
7 Posts 4 Posters 1.5k Views
  • VcelickaV Offline
    VcelickaV Offline
    Vcelicka
    Hi guys, something broke again need help 😅. I was normally riding and out of nowhere my front light stopped working…..
    I tried changing the light bulb but nothing i dont have a voltmeter so i dont know if there is any voltage? What should i check ?
    • VcelickaV Vcelicka
      @Vcelicka Start by giving the handlebar switch a good dose of WD40 as these always get neglected, it's a harsh environment for a switch.
      Use a full can with the straw on the end and spray loads in so it fizzes and bubbles out of all the holes, then operate the switch about 20 times to clean the contacts and free up all the little springs etc inside. Hold a rag underneath so you don't get any on the front brake. Good idea to do this after every time you wash the bike to make the switches last a lot longer.
      Stevie WonderS VcelickaV 2 Replies Last reply
        @Vcelicka
        No high or low beam?…
        Is the taillight working?…
        Check the black earth wire to/from the bulb…
        VcelickaV 1 Reply Last reply
          Stevie WonderS Offline
          Stevie Wonder
          @HOTSHOT-III WD40 also does a brilliant job at reviving plastic and giving it a bit of shine so you’re doing jobs at once if you use your WD40 soaked cloth to give all your plastics a wipe
            @Vcelicka
            VcelickaV Offline
            VcelickaV Offline
            Vcelicka
            Its just no beam the small side bulb idk what is called is working but the main one doesn . Taillight is working just fine
              VcelickaV Offline
              VcelickaV Offline
              Vcelicka
              Just did still nothing
                @Vcelicka
                Gonna have to check your wiring behind the headlight 🙂 …
