  3. DTX
  4. Bike dies randomly
Bike dies randomly
4 Posts 2 Posters 1.1k Views
  • fishy fishF
    fishy fishF
    fishy fish
    Hello guys have a massive problem with my dtx
    It idles good at low rpm runs great but if you give her more rmp she just shuts down. After that she start easy but same thing again and again. I think it’s electric problem and I don’t know where to look
    Magnet have some scratches on it
      Hi there,
      It will be very unlikely to be the magneto as the bike runs off the battery and the output from the stator is rectified to 12V.
      Based off of your very basic description, some of the common pinch points are:
      • Faulty battery
      • Faulty wiring
        • Check ignition barrel leads to loom
        • Side Stand Switch
        • Kill Switch
      • Poor/Aftermarket Ignition Coil
        • I've had this problem myself with a Chinese Ignition Coil which basically resulted in the bike running great from cold, then once it warmed up the ignition would die above anything from 5k onwards
        • Replace with genuine 3RM Ignition Coil
      I am sure there are lots of reasons, but since you've only given a sentence to go by the above should do for now.
      Don't forget the Search function as others have experience similar issues and the common faults are well documented on here.
      fishy fishF 1 Reply Last reply
        Hi there,
        • Faulty battery
        • Faulty wiring
          • Side Stand Switch
          • Kill Switch
        fishy fishF
        fishy fishF
        fishy fish
        @Calum thanks Brother will look i have chinese coil thanks alot for the help
        • fishy fishF fishy fish
          @fishy-fish I'll put money it's that then.
