  4. Bike no longer starts help
9 Posts 2 Posters 841 Views
  • mbmO8M Offline
    mbmO8M Offline
    mbmO8
    wrote on last edited by mbmO8
    Hi all, I have a 99'DTR and after leaving a bike meet the bike felt slightly sluggish, this got worse as the trip went on and when I pulled over to check it cut out when I pulled in the clutch. The bike no longer starts and I have no clue what it is I have cleaned the carb (not incredibly thoroughly and have cleaned and have spark. (Yes I do have fresh fuel)
    Sometimes when I try to bump it will bang if that helps at all
    (Sorry if this is in the wrong page )
      What's the mileage on the engine? What's the health of the engine? Have you got a compression tester to check?
      Has the head gasket blown and you're leaking coolant into the engine. Stick your fingers into the radiator cap and check for the presence of any oil residue.
      • mbmO8M Offline
        mbmO8M Offline
        mbmO8
        To be honest I have no clue about the age of the Engine as I bought it last August and it came with like 3 top ends and a bottom
        I'm getting a compression tester from a friend sometime this week.
        What kind of residue would I find in the cap ?
          @Calum said in Bike no longer starts help:
          oil
          • mbmO8M Offline
            mbmO8M Offline
            mbmO8
            As I said earlier I cannot check my compression at the moment but it does feel like I have some
            When I checked my radiator I found my finger was dirty and the cap had a milky residue  Shown here
            I've heard before the milky residue could be a sign of a head gasket failure
              Yeah that looks like the head gasket.
              Did you dip your fingers into the neck?
              A compression test would tell you for sure as it'll be down on compression. But this is an indicator.
              A compression tester is like £20.
              https://www.ebay.co.uk/itm/167499985920?_skw=gunson+compression+tester&itmmeta=01JTP74TSF0N5BEDMP9VBQ7WCM&hash=item26ffc6f400:g:BXwAAOSwlhpoG3Cl&itmprp=enc%3AAQAKAAAA0FkggFvd1GGDu0w3yXCmi1fRWRe%2BDCnd%2Fv8ASPfYcwl4Qwe6G9UQ%2FUi8k0py2nze%2BaGESUbULwGf1He2oKCL4P8mfShHgcCAe7A1bXkgaijR5TEPPfOrSIvrYmzQb3dM8BDgU8JU5FDDAdAElgJH%2Fakz8RdSeFQARHDfao8VgDAERcjm9Z5MdcFSwi%2B6DHnh%2FdqVr4uDakoIcpV%2FQ5HjmuEEjfgpDcOQSxz7isQI7MNl1c%2FWpDDQSvpDTxjmFclGOKUCTbPqjBKAKGnqb6VjXBg%3D|tkp%3ABk9SR4Ctk8fVZQ
              Well worth getting one.
              • mbmO8M Offline
                mbmO8M Offline
                mbmO8
                My mate has one ill borrow it this week/weekend
                • mbmO8M Offline
                  mbmO8M Offline
                  mbmO8
                  Turns out my top piston ring went for a walk, full top end Rebuild in progress
                    You'll want to understand why that's happened before restarting the bike.
                    Lack of oil, incorrect piston ring end gap tolerance, or just generally tired engine, etc.
