  3. Carburetor
  4. Carburettor upgrade for stock dtr125 1999
2 Posts 2 Posters 667 Views
  • G Offline
    G Offline
    geardrop2t
    I would like to change my current stock carb since its a little old and need replacing i was thinking about purchasing a slightly bigger carb for a better throttle response what carb yall suggest (I prefer mikuni or other name brands)
      The Mikuni 28mm that is fitted from factory is a very good and serviceable unit. Before replacing it, it is well worth giving it a refurbishment first. They're also becoming like hens teeth and as such is well worth keeping ahold of.
      I ended up going with a 32mm Dellorto VHSA that's found on the same engine which is fitted to the TZR Belgarda.
