  3. Top End
  4. 4FU and 32mm vs Slightly Ported Athena 170 and stock carb and 290 Jets
10 Posts 5 Posters 921 Views
  • K Offline
    K Offline
    Karmona
    Hello, my question is the following:
    4FU and 32mm vs Slightly Ported Athena 170 and stock carb and 290 Jets?
    I have a dt 125 re, im slowly restoring, and in the engine department i was thinking either one of these two options, with maybe a cdi to maximize power performnace. I will still keep the oil deposit, so that is very important, and will use it very usually. The ported cilinder is on this link if anyone wants to look at the specs:
    https://www.rrd-preparation.com/en/kit-high-engine-motorcycle-125cc-2-times/671-kit-170-cc-athena-racing-for-motor-125-derbi-gpr-yamaha-tdr-dt-tzr-2-time.html
    (Optionally we offer you an internship 1 preparation, this preparation is a slight modification of the exhaust light by increasing the diagrams. Count an extra time for this preparation!) -> This is what they offer as stage 1 prep
    Thanks!!
      CDi is an absolute must if you're going modified.
      Having done most things on my DTR, I'd go ported Athena all day long. Stage 2 sounds good to me.
      The extra displacement just gives it a good punch, at the cost of overrev.
      If you're after a fast 125, ditch the DT platform and get yourself an Aprilia RX/MX/SX/RS Rotax bike.
      But if you want a faster DT, then the above is a good option.
      Get the Athena 170, Zeeltronic Ignition and a DEP pipe and you won't be disappointed.
      Bang for buck, a Rotax engine is going to be cheaper, but as I say, if you want to keep the DT, then that's a good option.
      • K Offline
        K Offline
        Karmona
        @calum That sounds nice, what im really after is wheelie power, and for it to be strong and for it to pull you know? Not like top end speed like 160 kmh, as this bike is clearly not built for going that fast, without spending a lot to prepare it, and it isnt really what i want it for. I want a strong, wheelie and just generel messing about machine, that has good pull and doesnt has a problem for overtaking and the likes. I dont know if that changes up things a little bit. Many many thanks for helping me out, its difficult here to get good answers locally about this bike.
          Well the extra CC's definitely helps with wheelie power. The CDI gives it a much need whack up the bum. The DEP not only massively reduces the weight (especially over the front end) but increases midrange.
          The porting work is something else. Porting is almost always a compromise, you don't get something for nothing as they say.
          The 170 does benefit from a port, and I mentioned in another thread, port matching will be required anyway, and the cylinder benefits from have the spigot machine to remove the obstruction into the DTs inlet air waves.
          You do those mods, and you'll have a lovely packing machine, that's for sure!
          K 2 Replies Last reply
            K Offline
            K Offline
            Karmona
            @Calum Well then that's absolutely nice, i'll get that setup then. I asked the guys at the shop and they told me that the standard 28 carb would go well with the 290 jets, would you do that or directly upgrade to a 32? Thats the last thing i would want to know before i commit to modify the engine as you said.
            Really, many thanks for your help. Once i get everything done, i'll post the bike in its ultimate form as i'd say haha
              K Offline
              K Offline
              Karmona
              @Calum Btw, i talked to the guy Romeu Enriques, he's in portugal so there would be no problem for him to ship the pipe to me, and said he could adjust it to a port. Would you reccomend his pipe or the dep one? I initially wanted a dep one for looks mainly but if it is better i'd buy the romeu one. And many people say its better some say DEP is better, who knows really hahaha just want to know your opinion on the matter. Have a nice weekend sir
                Jetting needs to be done to suit. With the upgrades you're proposing, I doubt it'll be enough for just a main jet. You'll be looking at a needle and idle jets as well.
                It is always my recommendation to jet to suit, I can't help here as I've never ran Athena on the stock carb.
                You will get benefits from a bigger carb, but the TM28 is a decent carb so you can always look to upgrade it later if you feel it's not quite working for you. For context, people tune RD350's with 28mm carbs, so I wouldn't be rushing out to replace yours on a whim.
                I use the TZR 4DL carb (Dellorto VHSA 32mm) on my ported Athena set.
                I run the Romeu Enriques pipe on my DT. It's been absolutely solid, not a spec of rust and I've had it 10+ years.
                The DEP one will rust no matter how hard you clean it. I had great success with both pipes, but I've stuck with the Romeu pipe.
                • MadGyverM Offline
                  MadGyverM Offline
                  @karmona Agree with most that @Calum said.
                  Athena170 the way to go.Porting is a must,depends what you need and who will do it.
                  DEP or any other good exhaust (the thing with rust is real for DEP,5 coats of high temp black on a clean brushed DEP,and still have 2 tiny spots of rust forming)
                  TM28 is ok, if it hasn't a power jet,install one.
                  CDI you choose. Aftermarker programmable is a wise choice. OEM CDI upgrade from another Yamaha is a good compromise,depends heavily on your setup,
                  • K Karmona
                    @Karmona @calum @madgyver Interesting thread, as I've never run an Athena 170cc kit I can only agree with all the above comments.
                    One thing I would like to add though is you might like to consider a Tecno expansion chamber, possibly as well as the RH and DEP pipes. These are relatively inexpensive and from what I can see are basically an Athena pipe (which your above link recommends with the Athena 170 kit) with a clearcoat finish instead of black or chrome plating. A few years ago I ran one with a DEP silencer on an otherwise stock 1993 3NC French import and it made the power come in about 1000rpm earlier than stock with a sharp cutoff at about 9000rpm. I did some measuring of that pipe and a DEP I also had at the time and according to the A. Graham Bell two-stroke tuning book, all other things being unchanged, the Tecno delivers peak HP revs about 600rpm earlier than the DEP (basically my riding experience on the 125) whereas the DEP allows more overrev. So if you want a 170cc midrange monster for wheelies etc. it might just be the ticket, and it would be interesting if you could establish the correct jetting etc for all three pipes once you've built the engine.
                    Only thing I don't like about the Tecno is the clearcoat which bubbles up around the header pipe and is very difficult to remove. Eventually I managed it using rags soaked in paint thinner just wrapped around the pipe and left for a while (do this outdoors!) before wire brushing but I had to do this a few times to remove it all. I wish they wouldn't do this as it actually looks quite "factory" with the bare metal/welding heat marks:
                    https://www.ebay.co.uk/itm/233679367459#:~:text=Item description from the seller,41%2C PH 49-50.&text=THIS IS A STANDARD PIPE,WILL NEED A COMPATIBLE SILENCER.&text=WE WILL COMBINE POSTAGE COSTS IF MORE THAN ONE ITEM IS BOUGHT.
                    • R Offline
                      R Offline
                      Rallyfinnen
                      I use the Athena pipe with the 170 cylinder, it works quite well, and most of the power is in the midrange, even if I can get it to rev higher with modified ignition curve, the torque is in the midrange. I have seen Mick Abbey writing somewhere that the stinger ID needs to be at least 22mm (or was it 23) with the 170 kit, so that is a bit tight at least with the Athena pipe. The black paint seems to hold up quite well on the Athena-branded version.
