Jetting the carb
Hey, guys im new.
I just got a yamaha dt125x from 2006, with a custom exhaust from romeu Henriquez. My question is wich jets i should buy for this exhaust? The bike is stock except i changed the reed valves to carbon ones en putted a spacer on the intake. Hope you guys can help me out
Unless required, I'd leave the jetting alone.
Even DEP recommend just leaving the jetting alone.
Once you get the pipe, warm the bike up and do a plug chop. If it's hesitant, bogging or the plug is not golden brown, then consider a rejet.
If you're running the stock DTX carb, then 210 is the stock jet. The earlier models came with 240 main jet.
@calum thanks for your reply. Stock jets are indeed present, main is 210 en idle is 17.5. my carb is a mikuni tm28ss. Bike bas bogging(buuhhh sound) if i twisted the throttle while idling when it was warm
@Elan-n Have you done a full carb clean including the emulsion tube?
@calum @hotshot-iii yes i did a full carb clean, took everything apart and cleaned it and i dont know, the seller told me it drives good and gave the original exhaust with the bike too. I also ordered an fully overhauled carb to replace it. Came in today and dontacted the seller from the exhaust and told me to use a 245 jet but havent tried it yet. Tomorrow im gonna install everything back
You should get a set of main jets and go up in size significantly until it runs too rich, then start going down until you find the sweet spot. You might need to raise the needle too if it bogs when you twist the throttle. You will probably notice problems when running abt half throttle if the needle is wrong. Keep an eye on the plug when you are jetting, if you have some experience in jetting, the feel and sound of the engine will tell you when you are close. I sometimes use Chinese jet kits and think they work ok, especially for the price, but you can't compare the numbering on them with anything else, you have to stay with that kit when you are jetting.
@rallyfinnen installed the overhauled carb, tried a whole lot of jets and ended with 210 but now it suddenly runs really bad, cant get past 4k rpm because it stutters really hard, sounds like a rev limiter.
Then I guess it's ignition related, might be hard to find the problem..
Are you using a genuine coil?
I had something very similar with a Chinese 'race' coil. Took me absolutely ages to get to the bottom of as I rebuilt the whole bike from the ground up and the coil was one of an assortment of new parts.
So I am very wary now of aftermarket coils.
@Elan-n You can make your own using stainless MTB gear cables, use the inline cable oilers as well and you can quickly re-lube them after every wash:
@calum @hotshot-iii @rallyfinnen All right! But so abaut the jetting, so i should have no restrictions on my 2006 dtx. The only upgrades that i have are the reeds that were switched to carbon ones and a spacer between the intake and the reeds. and also the purtagal pipe from romeuhenriques. Current jetting is: idle 17.5 and main 210. Am i supposed to follow the older model with the 240 jets or what should i start with?
Go with the 210 main jet, do a plug chop and adjust to suit.
The CDI on the 2006 DTX (at least in the UK) is restricted. So you won't be getting full power until you derestrict it, even then the performance is still stifled.
Biggest upgrade I noticed to overall performance was a
Zeeltronicignition system.Vastly improved the performance on my DTRE.
@Elan-n Agree with @calum about the Zeeltronic, I enjoyed the process of installing mine and making it look as stock as possible.
Re jetting, I think I'd be contacting Romeu Henriques, tell him about your other mods (intake spacer dimensions etc.) and see what he says. Everyone speaks very highly of his exhaust systems so he will probably have enough knowledge to plug the numbers into some two-stroke tuning equations and help you out.
@calum @hotshot-iii all right, i contacted the seller of the exhaust and he told me to use 245 main jet. So ill try that first. After some time ill get that zeeltronic. Firstly i want to get safely on the road. Piston replace gotta happen too because my piston has 22k kilometers but stil sounds good tho no ratlling or something but i want to be sure
#PotentialHandGrenade
https://www.youtube.com/shorts/0KlaU_adlWg
This was the state of my Raptor piston prior to me rebuilding it. Engine was running absolutely tip top prior to dismantling it. But this was a literal ticking time bomb.
