  3. Wheels
  4. Speedo gear missing
Speedo gear missing
4 Posts 3 Posters 22 Views
  • K Offline
    K Offline
    Kristóf
    wrote last edited by
    Hello! My Yamaha dt 125r is missing the speedo gear. Instead of the speedo gear someone put another spacer (the same one that fits on the other side, see picture). My question is that would this affect anything with the fork/wheel alignment? I don't mind that it's missing because I use the bike for off road and I don't need the speedo but if the forks don't align correctly that's a problem. Thanks
    • K Offline
      K Offline
      Kristóf
        wrote last edited by Calum
        I'd expect there would be a few issues, the bike wouldn't handle particularly well if the front and rear wheels were misaligned. The bike would have a tendency to crab.
         |     <-- Front wheel
        [  ]   <-- Frame
          |    <-- Rear wheel
        Figure: Exaggerated misalignment
        I'd be inclined to measure/check and if necessary locate and reinstall the speedo drive.
        • R Offline
          R Offline
          Rallyfinnen
          Check that the front wheel is centered in the fork, that should be enough. There should be no binding in the fork since one side is just a clamp.
