Please help! Dtre 07 not working properly?
Hello, my dtre has a strange problem and ive tried everything to fix it nothing has worked.
Problem is that it backfires through the exhaust not carb side.
Originally the problem was a blown head gasket since during a ride w my dad my dtre over heated and blew the gasket, i got new gaskets and also resurfaced the head, yet still has the same peoblem
I've confirmed it gets gas, spark and everything else it needs.
Ive tried
New plug
New coil
Adjusting the timing (i have HPI igniton)
New reeds
Also has a new piston set.I need to fiqure out whats the problem so i can finally start going to work with it.
Any suggestion or advice is really usefull
What head gasket did you use?
If the new head gasket was white in colour then it's probably the same culprit as the cheap head gaskets simply do not work. Use genuine, Athena or Vertex head gaskets only.
Did you install the head gasket with
UPfacing you? The head gaskets can be accidentally fitted upside down, which again will cause similar problems.When you say
New coilyou mean new genuine coil. Again the knock off chineseRacingcoils DO NOT work. So only use genuine ignition coils.I don't know what a HPI ignition is, but if you can source an OEM ignition system you can rule out faulty electronics.
Common problems on these engines will be things like, waterpump seal leaking into crank case and then crank seals leaking into engine combustion chamber. Both are pretty obvious but will cause running problems. And when I say common, they don't come up that often as the engines are pretty darn bullet proof.
