  4. Tachometer wiring
Tachometer wiring
3 Posts 2 Posters 192 Views
  • K
    K
    Kristóf
    Hello! I own a Yamaha DT125R but the tachometer wiring is cut, I could do it but I don't know exactly where the wires are supposed to connect to eachoter and how. I would highly appreciate it if someone could send detailed pictures of the wires inside the insulation (so I can see where to connect the wires). It's also missing the bulb socket for the headlight indicator, can that be replaced? Thanks!
      What specifically do you mean by cut? The Tachometer is mechanically driven on the DTR. So you need to replace the tachmeter cable back into the gearbox and the clocks.
      If you mean the lights etc, then there are many wiring diagrams already uploaded to this forum.
      Workshop manual is pinned: https://training.dt125r.co.uk/files/Yamaha_DT125_Workshop_Manual.pdf
      • K
        K
        Kristóf
        I meant the wiring for the bulbs. Thank you for the picture, the problem was that the diagram I found showed that the brown wires aren't supposed to be connected (brown from the thermometer, oil bulb, neutral bulb), mine showed that the thermometer needed to be connected to the oil bulb and that the neutral bulb brown needed to go straight into the 6pin connector, without connecting to the oil bulb or the neutral bulb. I didn't understand that but the diagram you sent made everything completely clear, thank you!
