  3. Framework
  4. YEIS mounting point on frame
3 Posts 2 Posters 148 Views
  • C
    C
    callum123
    Hi all, have just recently been rebuilding my bike, just refitted the engine and for some reason cannot work out where the YEIS chamber bolt any advice would be great. Thanks
      What year and which bottle?
      Early models only had the YEIS that goes into the inlet manifold.
      Later models had that ones that go into the carb boot.
      I don't recall them mounting to the frame however, it's merely attached via the carb inlet and the carb boot.
      • C
        C
        callum123
        Hi, thanks for the help it's a 1998, the one I have goes into the intake boot with a peice of tube which I would guess and say is around 250mm in length then the chamber sat on top. Will get some photos tonight
